Phillips #2 Screwdriver
  • Phillips #2 Screwdriver
US$ 2,99
US$ 2,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
Unless you require a #2 Phillips driver for a deeply recessed screw, we recommend purchasing our 6-in-1-Screwdriver, which includes a Phillips #2 driver.
Reparatieverhalen
Avatar
Mijn probleem
Computer was constantly running fans with little to no actual load. Upon closer investigation the computer was getting as high as 90 degrees Celsius when doing moderately demanding tasks.
Mijn oplossing
Opened the case and saw a bunch of dust everywhere. After the dust was removed the real problem revealed itself. . . .
Avatar
Mijn probleem
Replaced built in optical drive with 250GB SSD drive. System was running really slow.
Mijn oplossing
It went well. Followed instructions and was pretty straight forward. Ran into a few hurdles....The screws can easily fall down into the case, which was very annoying. There is also a cable that has a very sensitive . . .
Avatar
Mijn probleem
No facilities available in Australia, apparently.
Mijn oplossing
Quite ok. Thanx for online instructions.
Mijn advies
Spludger
invaluable.l
Avatar
Mijn probleem
My iMac 27 Inch i5 always frozen...
Mijn oplossing
Very well, I managed to happily. It 'just install "Fan control" fan set at maximum speed and the problem is solved!. For an excess of zeal, oh then apart my iMac 27 to carry out additional cleaning.
Mijn advies
No, nothing special
Avatar
Mijn probleem
The power supply of my Imac was broken
Mijn oplossing
My iMac is a 24" aluminum one, unfortunately there was no official guide on the website. However, there was a guide for changing the power supply in a 20" iMac, so I used that. There was also a video of the friendly lady, who made the repair look very easy. I al . . .
Geef meer weer
