Phillips #1 Screwdriver
  • Phillips #1 Screwdriver / iFixit - Made in Germany
  • Phillips #1 Screwdriver / Moody - Made in USA
$6.99
$6.99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision Phillips #1 screwdriver for DIY or professional electronics repair. The Phillips #1 screw is the most commonly used fastener in the internals of "larger" electronics like home theater hardware, game consoles, laptops, PCs, and server racks. This particular size of Phillips screwdriver blade is also known as Phillips 1, PH 1, and PH #1.
The iFixit Phillips #1 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Phillips screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
Avatar
knoykrmencita's Story Photo #615434
knoykrmencita's Story Photo #615440
knoykrmencita's Story Photo #615438
Mijn probleem
My computer didn't turn on. I took it to an Apple Store. They told me that this Machine is a Dinosaur. they didn't have the part and didn't gave me warranty if the part is not original.
Mijn oplossing
I start looking on the internet how can I repair the computer. Then I see a video on youtube. I place the order, t . . .
Avatar
MissHeather's Story Photo #593000
Mijn probleem
The computer was overheating pretty bad and it was hard to watch video or even play a simple game without the computer shutting off.
Mijn oplossing
It went really well. The tools made the whole process go really smoothly.
Mijn advies
I recommend taking your time, research the job before you start doing it, lay out all your tool . . .
Avatar
Mijn probleem
As common as the problem is, my PS4 was not turning on or no light would come on when attempting to.
Mijn oplossing
The Repair was immaculate! It was quick and easy and anyone can do it as long as you have the right tools for it. As a Technician in training, it gave me a boost of confidence to fix the harder stuff . . .
Avatar
Mijn probleem
The trigger on my X52 pro was stuck and wouldn't release unless I pressed it again hard and quick.
Mijn oplossing
Followed guide, opened it up, reseated the metal flap over the button and sealed it up again. Worked great!
Mijn advies
I didn't want to risk damaging the pinky button so I unscrewed it from the joystick. A bit of . . .
Avatar
Mijn probleem
My PS4 made a loud popping sound and wouldn't power on.
Mijn oplossing
Followed the IFIXIT tutorial on YouTube. Took less than five mins to repair. Saved me from purchasing another PS4.
Mijn advies
Subscribe to IFIXIT YouTube channel. Their tutorials are easy to follow.
Avatar
Mijn probleem
Needed to upgrade the SSD drive
Mijn oplossing
Great - The iMac runs like it is brand new
Mijn advies
Pricing and Shipping were hassle-free
Avatar
Mijn probleem
My early 2009 iMac was really lagging. I hated the ideas of buying a new one when most of the hardware was still in great shape. Therefore I decided to upgrade the hard drive to a solid state.
Mijn oplossing
Great! The performance has been fantastic and it really has given my computer and new life. Working slowly . . .
Avatar
Mijn probleem
A fonte do PS4 queimou apesar de estar conectada a um estabilizador. Acreditava ser uma atualização da Sony porém com uma chave p/ teste de corrente elétrica constatei que a energia não estava chegando aos conectores.
Mijn oplossing
Pelo vídeo do IFIX disponível no YouTube verifiquei como ocorria o reparo. S . . .
Avatar
Mijn probleem
Old original 4S battery
Mijn oplossing
really easy
Mijn advies
to buy it
Avatar
Mijn probleem
I decided my new Macbook Pro needed a new Solid State Drive. Since I was going to be inside the case anyway I decided to put in a Data Doubler from OWC. A Data Doubler basically is used to replace your optical drive with a hard drive or SSD. The SSD upgrade went off without a hitch. The Data Double . . .
Geef meer weer
