Phillips #000 Screwdriver
  • Phillips #000 Screwdriver
  • Phillips #000 Screwdriver / iFixit - Made in Germany
  • Phillips #000 Screwdriver / Moody - Made in USA
$8.99
$8.99
We zullen een bericht sturen als het product weer op voorraad is.
Verspreid de kerstsfeer
Krijg 12€ korting op je aankoop van 50€ of meer met de code FIXMAS12
Productdetails
Beschrijving
Beschrijving
Use this precision Phillips #000 screwdriver to handle smallest fasteners in consumer electronics, laptops, tables, smartphones, and wearables. The Phillips #000 screw is the smallest fastener in the Phillips family and is used in the most compact electronic applications. This particular size of Phillips screwdriver blade is also known as Phillips 000, PH 000, and PH #000.
The iFixit Phillips #000 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Phillips screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
Mijn probleem
Best Buy damaged my charging port when trying to clear out to Bri. While the rest of the phone worked by could no longer power it on.
Mijn oplossing
The tools and parts supplied or packaged and organized very professionally. Step-by-step guide was thorough and to the point. There were not any surprises in the repai . . .
Mijn probleem
The screen was blank when the power was on.
Mijn oplossing
I took the battery out and blew on the circuitry.
Mijn advies
Don't break the battery.
Mijn probleem
Not enough ram
Mijn oplossing
It worked well and easily
Mijn advies
No?
Mijn probleem
Iphone drained battery had to repair, but didnt have tools... Lost em
Mijn oplossing
Easy fix just waited for shipping
Mijn advies
Beready for a long but worthwhile wait for shipping, mine didnt have tracking but was told earlier on that if have to wait 2-7 weeks for it to come
Mijn probleem
I was having issues with my Wifi Dropping a lot. After researching I found out that there was an issue with the Airport/Bluetooth Cable.... so rather then paying Apple to diagnose that I needed a new Airport/Bluetooth Cable and charge me an arm and a leg to repair it... i figure I would try this ou . . .
Mijn probleem
My Iphone 5s developed a microphone issue after a few months of use. I couldn't be heard when making a phone call unless I used my speakerphone. I tried dealing with my cellphone carrier on a repair or replacement as it was under warranty. They sent me a "like new" replacement however this "new" pho . . .
Mijn probleem
Both phones (iPhone 5 and Moto X) had batteries older than 2 years and required frequent charging.
Mijn oplossing
Both phones were relatively easy to repair. Your guides and uTube videos were very helpful. Also other uTube videos not from ifixit were informative as well. Be very careful to check the iPhone power s . . .
Mijn probleem
bought tools and screen
Mijn oplossing
tricky but I managed.
Mijn advies
No. It is all very well explained. I must be done with calm and concentration. Thankyou
Mijn probleem
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
Mijn oplossing
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
Mijn probleem
Because my BEAUTIFUL daughter is a clutz!
Mijn oplossing
Just like it should, thanks to your how to video!!
Mijn advies
Be patient and have a work space away from distraction and animals, allow plenty of time for the first one, LOL! the second one goes smoother!
Geef meer weer
