Phillips #00 Screwdriver
  • Phillips #00 Screwdriver
  • Phillips #00 Screwdriver / iFixit - Made in Germany
  • Phillips #00 Screwdriver / Moody - Made in USA
US$ 6,99
US$ 6,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision Phillips #00 screwdriver for DIY or professional small electronics repair. The Phillips #00 screw is the most commonly used fastener in the internals of consumer electronics, game consoles, laptops, PC desktop computers, and small home appliances. This particular size of Phillips screwdriver blade is also known as Phillips 00, PH 00, and PH #00.
The iFixit Phillips #00 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Phillips screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
William Vaughan's Story Photo #1168254
William Vaughan's Story Photo #1168256
William Vaughan's Story Photo #1168257
Mijn probleem
This is my fairly new Dell XPS 13 (9360), 7 months old. The battery stopped working so I ordered a new one to replace it.
Mijn oplossing
Disassembly / reassembly as specified in the IFIXIT article worked exactly as specified. I removed the original battery, opened up the package I had ordered with the new battery, . . .
John Joslin's Story Photo #1334073
Mijn probleem
No power, dead battery, etc.
Mijn oplossing
I decided to do a couple of other errands since I was going to be in the area :) .... so I replaced the Fan ( ...still good but 9 years old ! ) , Subwoofer/Right Speaker, & the Left Speaker ( BOTH speakers bad ; buzzy, garbled sound ...) , as well as the defective MagSaf . . .
Mijn probleem
I broken the display.
Mijn oplossing
With your help very early.
Mijn advies
How long do i have warranty?
Mijn probleem
Had to change micro SD card slot in Nintendo switch. Super glue got into it.
Mijn oplossing
Good
Mijn advies
Don’t use super glue near a nintendo switch.
Mijn probleem
The battery died from age and repeated charges.
Mijn oplossing
I was able to remove the battery without difficulty after carefully following all the steps listed--and will all the recommended tools I purchased from ifixit. Now I'm just waiting on my new watch battery to arrive from an outside vendor, so that I can . . .
Mijn probleem
Dead swollen battery & slow memory
Mijn oplossing
Pretty Smooth some of the screws were hard to loosen up.
Mijn advies
I was at first affraid of opening the computer to make the repairs & put it off for years . I wish I had done it sooner.
Mijn probleem
My optical drive had failed sometime in the past. I rarely used it. Recently I was doing upgrades to other components and decided to replace the Superdrive.
Mijn oplossing
The repair went very well. I was surprised when the internals of my MacBook did not quite match the repair guide. I had to rely on some per . . .
Mijn probleem
Battery expired
Mijn oplossing
Video made it easy along with the tools I purchased
Mijn advies
I would just say that whomever is considering doing this buy the tools. They are a few bucks but made this job simple.
Mijn probleem
Tried to remove battery to replace original that was not holding a charge very long
Mijn oplossing
The blue pry tools got the chassis opened, with a little effort to get the front/back separated
Mijn advies
The small locking tabs that hold circuit strips are very small and take no effort to open. Unfortunately for me, the blue . . .
Mijn probleem
My tablet was stuck on bootloop for a few months, and after flashing every stock ROM file I could find, I found that it was the motherboard that was faulty.
Mijn oplossing
The repair was easier than I thought, and it took less time than I thought! It was my first time repairing hardware so it was really exciting to . . .
Geef meer weer
