Phillips #0 Screwdriver
  • Phillips #0 Screwdriver
  • Phillips #0 Screwdriver / iFixit - Made in Germany
  • Phillips #0 Screwdriver / Moody - Made in USA
US$ 6,99
US$ 6,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision Phillips #0 screwdriver for electronics repair and DIY projects. The Phillips #0 screw is one of the most commonly used fasteners in consumer electronics, game consoles, laptops, PC desktop computers, and small home appliances. This particular size of Phillips screwdriver blade is also known as Phillips 0, PH 0, and PH #0.
The iFixit Phillips #0 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Phillips screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
doshry's Story Photo #695092
Mijn probleem
Had to upgrade my G4 Cube!
Mijn oplossing
Perfect! I feel like a brain surgeon!
Mijn advies
Make sure you get the right tools and follow the right guides! I know a website :-p
Mijn probleem
Needed battery for my Honda key fob
Mijn oplossing
This key fob requires the removal of an extremely small phillips screw to separate the key fob to access the battery; I had a couple of small screw drivers on hand and proceded with them but could not break the screw lose. I started rounding the phillip + out and t . . .
Mijn probleem
I broke a headphone jack off in the Kindle
Mijn oplossing
A co-worker of mine actually did the repair. He said the step-by-step instructions and photos made this repair so easy.
Mijn advies
Get the screwdriver, the tool to open the Kindle, the instructions and an extra set of hands. I opted to not separate the top from the bo . . .
Mijn probleem
Music is my life. I've learned I can access it through my phone. To be polite to those around me, I use headphones and my phone's headphone jack.
One day, out of the blue, my phone only provided me with my fix through my right earbud. I cussed out the previous night's drunk me. I originally bla . . .
Mijn probleem
Headphone jack connection became flaky. Typically only on channel would work (i.e. sound only out of left speaker)
Mijn oplossing
Followed "Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement" guide. Repair was very quick, cheap, and effective.
Mijn advies
The #0 Phillips seemed a bit too big for the screws. It . . .
Mijn probleem
Battery needed replaced
Mijn oplossing
Great
Mijn advies
Everything went well following the guide.
Mijn probleem
Dropped the phone and the speaker stopped working
Mijn oplossing
Success! The new speaker assembly works like new and I have sound again. I should have been more careful taking the back off because I knocked two clips off - it still fits back in place but has a small creak to it.
Mijn advies
You DO NOT have to remove the batter . . .
Mijn probleem
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
Mijn oplossing
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
Mijn probleem
A friend of mine has young children that were playing on their friends iPad and, after some elevated excitement, managed to drop the iPad. The bottom corner hit the ground and the digitizer shattered.
Mijn oplossing
The repair was initially difficult with the standard tools recommended. The plastic tools bend too e . . .
Mijn probleem
it was headphone jack was beoke
Mijn oplossing
good
Mijn advies
thanks
Geef meer weer
