P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone / iFixit - Made in Germany / New
  • P2 Pentalobe Screwdriver iPhone / Moody - Made in USA / New
US$ 8,99
US$ 8,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Use this precision P2 pentalobe screwdriver to open iPhone and Apple devices. The P2 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of iPhones. The driver is compatible with the security screws on the bottom of all models of iPhone since the iPhone 4: iPhone 4/4S, iPhone 5/5s/5c, iPhone 6/6 Plus/6s/6s Plus, iPhone SE, iPhone 7/7 Plus, and iPhone 8/8 Plus.
The iFixit P2 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P2 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatieverhalen
Mijn probleem
Input via digitizer became intermittently erratic. I could scroll screen with finger above screen not touching. Pressing one area made phone act like I had pressed a different area. There was a light streak down screen. This problem was intermittent and would come and go while phone was just sit . . .
Mijn probleem
Battery was draining within 2 hours and % remaining was never accurate (at 100%) and then would die.
Mijn oplossing
Super simple! Make sure that you have that pentalobe (?) screw driver.
Mijn advies
My battery was taped in with double sided tape. And was very difficult to remove until I heated up the tape. I heated up a hot/ . . .
Mijn probleem
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
Mijn oplossing
Very well.
Mijn advies
NA
Mijn probleem
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
Mijn oplossing
Perfectly
Mijn advies
Saw a video on you tube
Mijn probleem
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
Mijn oplossing
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
Mijn advies
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
Mijn probleem
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
Mijn oplossing
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
Mijn probleem
I water damaged my 6s.
Mijn oplossing
It went great!
Mijn advies
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
Mijn probleem
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
Mijn oplossing
Took less than a minute, super super easy
Mijn advies
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
Mijn probleem
screen cracked
Mijn oplossing
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
Mijn probleem
Cracked display
Mijn oplossing
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
Mijn advies
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
Geef meer weer
