Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Manta Driver Kit - Refurbished
  • Manta Driver Kit - Refurbished
Niet te koop
Niet te Koop
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
Productdetails
Beschrijving
Beschrijving
Get your Manta Driver Kit at a discount by choosing to buy Refurbished. All our refurbished toolkits have been thoroughly checked for missing or damaged bits and tools—and any less-than-perfect component has been replaced. Most of our "refurbished" items are simply legacy toolkits that were returned to us out of their packaging with no signs of wear or use. Best of all, these toolkits are covered by iFixit's Lifetime Warranty.
Inhoud van de Kit
Inhoud van de Kit
  • Easy-to-Open Magnetized Case
  • Lid with Built-in Sorting Tray
  • 4 mm Aluminum Bit Driver
  • 1/4" Aluminum Bit Driver
  • 4 mm Screwdriver Bits
    • Phillips - 000, 00, 0
    • Flathead - 1, 1.5, 2, 2.5, 3, 3.5 mm
    • Torx - T2, T3, T4, T5
    • Torx Security - TR6, TR7, TR8
    • Pentalobe - P2, P5, P6
    • JIS - 000, 00, 0, 1
    • Hex - 0.7, 0.9, 1.3, 1.5 mm
    • Hex Security - 2, 2.5, 3, 3.5 mm
    • Tri-point - Y000, Y00, Y0, Y1
    • Nut driver - 2.5, 3, 3.5, 4, 4.5, 5, 5.5 mm
    • Gamebit - 3.8, 4.5 mm
    • Spanner - 4, 6
    • Triangle - 2, 2.2, 2.6, 3 mm
    • Oval Bit
    • iPhone Standoff Bit
    • Sim Eject Bit
    • Magnetic Pickup Bit
  • 1/4" Screwdriver Bits
    • Phillips - 1, 2, 3
    • Flathead - 4, 6, 7, 8 mm
    • Hex Security - 4, 5, 6, 7, 8 mm
    • Hex Security SAE - 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
    • Pozidriv - PZ0, PZ1, PZ2, PZ3
    • Torq-set - 6, 8, 10
    • Spanner - 8, 10, 12
    • Square - 0, 1, 2, 3
    • Spline - M5, M6, M8
    • Torx Security - TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
    • Tri-wing 1, 2, 3, 4
    • Clutch 1, 2, 3
    • Schrader Valve
    • Hook Drive
    • 1/4" to 4 mm Adapter
    • 1/4" Driver to 1/4" Socket
    • 1/4" Driver to 3/8" Socket
    • 1/4" Socket to 1/4" Driver
Klantbeoordelingen
