Mac mini Logic Board Removal Tool
  • Mac mini Logic Board Removal Tool / Stainless Steel
US$ 4,99
US$ 4,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
Productdetails
Beschrijving
Beschrijving
  • Simple tool pries the logic board free to allow access to the hard drive in 2010 to 2014 Mac minis.
  • Custom iFixit version is nearly indistinguishable from Apple's official logic board removal tool.
Compatibiliteit
Mac Mini Late 2012
2.3 GHz (Quad i7)
2.5 GHz (Dual i5)
2.6 GHz (Quad i7)
Mac Mini Late 2014
1.4 GHz (Dual i5)
2.6 GHz (Dual i5)
2.8 GHz (Dual i5)
3.0 GHz (Dual i7)
Mac Mini Mid 2010
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
Mac Mini Mid 2011
2 GHz (Quad i7)
2.3 GHz (Dual i5)
2.5 GHz (Dual i5)
2.7 GHz (Dual i7)
Nog 1 apparaat tonen
Reparatieverhalen
Avatar
Mijn probleem
Upgrade to SSD
Mijn oplossing
Found out the hard way you need to reformat the SSD before installing in the Mac mini. Otherwise it went fine.
Mijn advies
Note in the guide to reformat the SSD before installing into the Mac mini
Avatar
Mijn probleem
replaced HDD with SSD
Mijn oplossing
did not need tool to remove logic board but screen did not fit back could not use one screw
Mijn advies
take risks but use good tools
Avatar
Mijn probleem
One day my Mac Mini would not wake up. Leading up to this it was acting a bit unreliable.
Mijn oplossing
I started with first unplugging the power supply from the logic board and measuring the power supply output with a multi-meter to ensure that was not the issue. It puts out a simple 12V to the logic board so i . . .
Avatar
Mijn probleem
Not a problem but an upgrade. A friend of a friend was in the market for a new computer and I convinced him to buy a Mac. A large selling point was the ability to purchase an older Mac and install a second drive and install Windows on it in the off chance he'd ever want to go back to it.
Mijn oplossing
"Repair" its . . .
Avatar
Mijn probleem
My original 500GB hard drive was very SLOW .
Mijn oplossing
Super easy. Followed the instructions provided on ifixit.com, easy to follow and step by step. I was up and running within an hour. Now my Mac Mini is FAST!!
Mijn advies
1. Backup to Time Machine First - restore is fast and easy.
2. Follow the instructions for a co . . .
Avatar
Mijn probleem
The hard drive was to slow - change it to a SSD
Mijn oplossing
Followed the repair guid for harddisk installation, and the guide was really helpful.
Mijn advies
Take your time and read the guid carefully. If you do, you will not go wrong
Avatar
Mijn probleem
I was receiving a SMART report of imminent failure, so I replaced it with a Crucial MX300 SSD
Mijn oplossing
Two issues: the IR sensor was not observed. And the insertion into the drive slots was very tedious. The drive did not want to go into the two holes in the case. I also replaced the Mac mini cooling fan whi . . .
Avatar
Mijn probleem
Slow mechanical hard drive - upgrade to SSD.
Mijn oplossing
Went smoothly.
Mijn advies
Could have used some closeups on the removal of the power plug clip - you just pull it out, but it wasn't clear if it was supposed to levered up or down. Also, could have used a closeup on pulling the power connector off the logic board; it d . . .
Avatar
Mijn probleem
I was tired of long boot times and slow program launches on my late 2014 Mac Mini. Even with 16 GB of RAM, the thing was pokey.
Mijn oplossing
The 2014 Mac Mini wasn't the most difficult Mac to work on that I've ever encountered, that honor goes to the pre-Unibody Macbook Pro. Ugh. Replacing the hard drive in the M . . .
Avatar
Mijn probleem
I thought I could live with a slow spinning drive - I couldn't...
Mijn oplossing
The replacement went without a hitch. I was dreading some kind of hiccup along the way, but the directions were so clear and detailed, I knew what to expect at each step. So in the end, I was able to successfully replacement my stock . . .
Geef meer weer
