Heavy-Duty Spudger
  • Heavy-Duty Spudger
  • 360°
360
Heavy-Duty Spudger
US$ 4,99
US$ 4,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Poke and prod like you mean it.
  • Thicker variant of the official "black stick" that Apple Certified Technicians use to repair Apple computers.
  • 6" long antistatic nylon probe with one flat end and one pointed end.
  • Flat end can be used to disconnect connectors, remove thermal paste from heat sinks, pry off components, or aid in soldering.
  • Pointed tip is handy for unlocking ZIF connectors and poking your siblings.
Reparatieverhalen
Ahmed Lotfy's Story Photo #738396
Ahmed Lotfy's Story Photo #738398
Ahmed Lotfy's Story Photo #738401
Mijn probleem
To replace my 2639 iMac (27" late 2013) HDD with Samsung 850 PRO SSD
Mijn oplossing
It went smooth, thanks to iFixit guides, videos, and tools
Mijn advies
Take your time to plan and prepare for it, handle the screen with extra care, no need to completely remove the left speaker if you plan to replace the HDD; only moving it a l . . .
Mijn probleem
Battery would last about 4 hours from a full charge.
Mijn oplossing
super simple, took about 45 minutes from opening ifixit.com to turning the phone on again.
Mijn advies
get good tools from ifixit first, they made all the difference.
Mijn probleem
My battery was draining very fast when it got to 30% and the lighting connector was failing
Mijn oplossing
The repair took about 3 hours in two sessions. The last step of the lighting connector assembly replacement guide was missing the step at the end to separate the microphone cable from the plastic microphone i . . .
Mijn probleem
Got my old iPhone 5 back in shape to let the kids share
Mijn oplossing
Piece of cake. I have repaired a couple of other phones (with iFixit's help!) so I knew what to expect.
Mijn advies
Follow the online guides! They tell you how to go and what to expect. I prefer the text with pictures, but there are videos too.
Mijn probleem
My 18-month-old launched her Mom's iPhone 6 in the toilet, and then started crying, haha. I was at work when it happened, but Mom said that when she pulled it out of the toilet, she tried to turn it off but wasn't able to - and then she said it got hot... really hot. So, I figured that the battery . . .
Mijn probleem
WiFi would work when MacBook was cold then stop later
Mijn oplossing
Great! It's working again and the instructions on iFixIt's web site were perfect.
Mijn advies
I, for some reason, always considered Macs untouchable for repair even though I've routinely opened and fixed Windows PCs for years. That is gone! Macs are fixable! W . . .
Mijn probleem
Battery was original and only charging to 67% of original capacity. Mac Superstore wanted $150.00 for replacement. With iFixit instructions and their excellent pentalobe driver, I did the replacement in 30 minutes, for a total of $75.00 including the battery.
Mijn oplossing
The repair was without any issues. The iF . . .
Mijn probleem
Computer refused to boot which was narrowed down after many other suggested remedies to a defective power supply. Replacing the power supply was not something that I had ever done before. But with the very detailed description given by Chris Green led me to a successful disassembly and removal of th . . .
Mijn probleem
Only had one ear bud (also one speaker when using accessory on car radio).
Mijn oplossing
One hour had iPod apart,changed out earphone jack and battery (figured y not while I had it apart) and back together.
Mijn advies
Plastic separaters weren't really used,small putty knife,metal AND plastic spudgers are a must. 00 Phillips s . . .
Mijn probleem
Battery 6+years old, finally required a nonstop plug in charge. Basically, a desktop laptop. Slow and lots of beach balls was a normal function.
Mijn oplossing
So, I scouted this iFixit site and logged it for later. After reading many reviews. I was sold on the battery for sure. The information was spot on. Many re . . .
Geef meer weer
