Detailing Brush
  • Detailing Brush / Nylon
  • Detailing Brush / Brass
Detailing Brush
US$ 2,99
US$ 2,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
Productdetails
Beschrijving
Beschrijving
No more worn out toothbrushes with bent bristles, these economic professional tools will do the job faster and better, fitting into more places, and don't require handle bending pressure to do a good job. These bristles are ready to scrub and clean with minimal effort.
This double ended brush will fit in tight spaces and quickly cleans up battery acid damage, residue from spills, corrosion from water damage, dust, and thermal paste residue.
Notitie
This brush is safe for most applications, but is not an official "ESD safe" tool.
Reparatieverhalen
Avatar
Mijn probleem
Water damage on a macbook pro.
There was a dime sized bit of corrosion on the logic board and it would not turn on.
Mijn oplossing
Pulled the back off, unhooked the battery, stogged the corroded bits with a really soft brush and alcohol. Let it dry, put it back together and it turned back on.
Mijn advies
Be brave...
Avatar
Mijn probleem
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
Mijn oplossing
Repairs go a lot quicker with the right tools.
Mijn advies
Make sure you have the ri . . .
Avatar
Mijn probleem
Bass from speakers just come out as muddled.
Mijn oplossing
Removed without much trouble.
Mijn advies
The original screws securing the sub-woofer strips quit easily. Pay attention when removing them. I had to discard one screw I stripped. Luckily I could remove them by forcing the screwdriver into the screw to create new indent . . .
Avatar
Mijn probleem
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
Mijn oplossing
Excellently
Mijn advies
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
Avatar
Mijn probleem
Just needed some more tools for opening Apple Mac's, Getting out laptop screws that have had there heads destroyed and the magnetic project mat for the laptop screws.
Mijn oplossing
Always good
Mijn advies
By the right tools for the right job and it always easier.
Geef meer weer
