Anti-Static Project Tray
  • Anti-Static Project Tray
US$ 4,99
US$ 4,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Organize and Store Your Projects
  • Invaluable for all electronics projects and repairs.
  • Store tiny components and screws in the 20 small compartments, store large components and tools in the larger compartments.
  • Made from Anti-Static Plastic, so it's safe for delicate components.
  • Use in conjunction with our screwmaps for repairs on our most popular smartphone guides.
Great for phone repair! Put your standard size smartphone in the side compartment, store your tools in the bottom compartment, and organize your screws and parts in the small compartments.
Productvideo
Reparatieverhalen
Patrick Gold's Story Photo #854501
Patrick Gold's Story Photo #854502
Mijn probleem
iPhone 6 screen glass was shattered.
Mijn oplossing
Repair went fairly smoothly. Some of the ribbon cables were a bit stressful to pull off their adhesive.
Mijn advies
Go very slowly on those ribbon cables. Using the spudger helps a lot. Project tray was an absolute life saver. Those screws are tiny and want to roll around . . .
Shawn Carpenter's Story Photo #1417292
Mijn probleem
Over the past several months, I started noticing a significant decrease in battery life on my iPhone 6. It used to go two or even three days without a charge, but it got to the point where it wouldn't even get through one day and started just shutting off even with 26% or so remaining.
Mijn oplossing
Overall, compa . . .
Scott Sessions's Story Photo #1314027
Mijn probleem
My iPhone's Lightning connector was difficult to plug in successfully. I tried cleaning it out, thinking it might be dusty or grimy inside, but it made no difference. I've had the iPhone SE for almost 2 years and have also noticed that the battery performance was getting worse and worse. It turned o . . .
Adam Vaught's Story Photo #1000667
Mijn probleem
Device was out of warranty and I had the spare parts from another similar device.
Mijn oplossing
I made myself a chart to put underneath it while I work. It's paired with my step by step instructions I make for myself while I disassemble something. As I take something apart I put the screws/parts in the tray. Then . . .
Mijn probleem
My son spilled syrup onto the controller, leaving it unusable. I didn’t need to replace the buttons as cleaning the them did the trick to restore usability
Mijn oplossing
Great
Mijn advies
Definitely purchase a set of security Torx screwdrivers
Mijn probleem
I had no Cell service but wifi was working fine. I was suggested to replace the antenna flex cable and it was way cheaper than buying a new phone
Mijn oplossing
went well. bought the anti static project tray which stored all screws by step. Highly suggested buying it.
Mijn advies
have patience and take your time.
Mijn probleem
The iPhone was alerting me that my battery might need replacement
Mijn oplossing
The instructions didn't adequately explain what happens to the adhesive strip that seals the case perimeter. Some adhesive stayed with the back panel, some stayed with the front panel, and a lot of it stretched out between the two. Lea . . .
Mijn probleem
I'm pretty sure there was salt water damage to my phone. It was in my side pocket when I hauled my boat out of the water after a 21 day trip in Barkley Sound. I'd kept the phone in a waterproof pouch all that time, then had it out at the end while I was unloading and I guess my legs were deeper in t . . .
Mijn probleem
The display on my Iphone 4s broke from skateboarding. I tried to upload some before and after photos but the page keeps timing out.
Mijn oplossing
The repair went great. I love IFIXIT! I utilized the pro tech toolkit. Unfortunately I fell again though guys so I will be doing this repair again, and the back as well. . . .
Mijn probleem
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
Mijn oplossing
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
Geef meer weer
