Repareer je spullen
Recht op reparatie
Winkel
iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
  • iMac Intel 20" 2.4/2.66 GHz EMC 2210 Power Supply
US$ 139,99
US$ 139,99
Productdetails
Beschrijving
Beschrijving
Bring your iMac back to life!
Compatibiliteit
Compatibiliteit
  • 2.4 (EMC No. 2210) and 2.66 (EMC No. 2210) GHz 20" Intel iMacs
Specificaties
Specificaties
Part #:
661-4670 , 614-0438
Installatievideo
Compatibiliteit
iMac Intel 20" EMC 2133 and 2210
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
Reparatieverhalen
Gebruikersavatar
Chee Yong Koo's Story Photo #364177
Mijn probleem
Power supply went unserviceable after 5 years of usage.
Mijn oplossing
it definitely took an hour or so but the repair was slow, steady but smooth.
Mijn advies
Current guide was good enough however major improvements could have been made in the video where certain parts of "disconnecting cables /parts " of hardware made cleared . . .
Gebruikersavatar
Mijn probleem
I woke up one morning to find a dead iMac (2008 20" 2.66 ghz), and then noticed the house power had gone out during the night. I like the iMac, and it synchs with my iPhone, so I decided to repair it. Also, it had 13,000 family photos going back to 2003.
Mijn oplossing
The repair went smoothly, even with help from . . .
Gebruikersavatar
Mijn probleem
My wife has a 20" Intel iMac (EMC No. 2210) which had slowed to a crawl and eventually failed to boot. I have always had PC's and wasn't shy about swapping out hard drives and performing basic hardware repairs or upgrades. I wasn't eager to go out and spend a couple grand on another Apple computer . . .
Gebruikersavatar
Mijn probleem
the iphone had a broken glass display was working.The imac mod a1224 emc nr 2210 stopped working for a friend in the music aranger and musican.powersuply was the problem i found out with help fom your informative site and videos.worked with electroniks for 30 years.
Mijn oplossing
The iphone 5s i have bougth a disp . . .
Gebruikersavatar
Mijn probleem
Power supply burned out during electrical storm. Insurance declined to fix or replace as machine no longer supported by Apple. Insurance company paid me $250 which more than covered the cost of a replacement power supply from iFixit.
Mijn oplossing
No problems, easy-peasy, with instructions from iFixit lady on yout . . .
Gebruikersavatar
Mijn probleem
20" iMac EMC 2210: Overheating power supply caused a slight discoloration of the LCD screen on the corner in front of the power supply. It was also causing intermittent short term cut off of power which caused problems with the Hard Drive, That was the reason it was brought in for service.
Mijn oplossing
Used the . . .
Gebruikersavatar
Mijn probleem
We had a brownout and the iMac shut itself off. It wouldn't turn back on. I unplugged it from the wall for thirty seconds and it turned on and shut itself off again. It would not run longer than 5 minutes. So I ordered the power supply.
Mijn oplossing
The repair went smoothly. The only trouble I had with the disass . . .
Gebruikersavatar
Mijn probleem
My 20" iMac simply stopped working one evening recently while I was streaming music to my Apple TV. I did a little research and found there were diagnostic lights on the bottom. I saw light #1 (which indicates if the unit is getting power) was blinking and "guessed" the power supply had gone bad. . . .
Gebruikersavatar
Mijn probleem
My desktop iMac suddenly does not turn on any more - I tried everything I can check from internet sources, from checking power cables to reseting power management, all unsuccessful. Thanks to an iFixit guide and comments, I checked the power supply unit inside iMac and appeared to be the problem, z . . .
Gebruikersavatar
Mijn probleem
My iMac started acting funky. At first it just did not want to start up after a power failure. Sometimes it would just sit there and a few hours later power on. Strange very strange. Finally, it simply refused to power up. No chimes, no fan noise, no nothing. Just a door stop. What could it b . . .
Geef meer weer
