iMac 20" 2 GHz (EMC No. 2105) Hard Drives (SATA)
Replacement parts for your iMac 20" 2 GHz (EMC No. 2105) model to fix your broken computer!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Onderdelen compatibel met iMac 20" 2 GHz (EMC No. 2105):
2 TB 3.5" Hard Drive
Replace or upgrade the hard drive in your compatible iMac with this part.
1 TB 7200 RPM 3.5" Hard Drive
4 TB 3.5" Hard Drive
2 TB SSD Hybrid 3.5" Hard Drive
1 TB SSD Hybrid 3.5" Hard Drive
Apparaat Informatie
This rendition is Apple's first desktop machine to feature Intel processing. The Core Duo processor dramatically increased speed, compared to its predecessors. This version is also the first to support screen-spanning without hacks.
Need more memory? Two PC2-5300 1 GB RAM chips will max out your memory at 2 GB. A 2 TB SATA hard drive will top you off.
Select your category below or browse all compatible parts to find what you need to fix your machine!
