Onderdelen Mac iMac 20" 2 GHz (EMC No. 2105) AC Inlets
Winkel
Weet u het type niet? Identificeer je Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$ 8,99
iMac Service Wedge / New
iMac Service Wedge
Foam support wedge for holding heavy computers in place.
US$ 12,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$ 7,99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
US$ 24,99
1 TB SSD Hybrid 3.5" Hard Drive / New / Part Only
Replace or upgrade the hard drive in your compatible iMac with this part.
US$ 109,99
PC2-5300 1 GB RAM Chip
RAM Upgrade / 1 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz
US$ 8,99
iMac G5/Intel Power Supply
Power supply for iMac G5 and iMac Intel 17" & 20". Compatible with 1.9 GHz 17" G5 iMacs (Excluding EMC No. 2124) 2.1 GHz 20" G5 iMacs All 17" Intel iMacs and 2 (EMC No. 2...
Van US$ 39,99
iMac Intel 17", 20", and 24" 2006 SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your iMac Intel 17", 20", and 24" with this SSD upgrade bundle.
Van US$ 99,99
iMac Intel 20" EMC 2105 (Early 2006) Memory Maxxer RAM Upgrade Kit
Max your iMac Intel 20" EMC 2105 (Early 2006) with 2 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac.
US$ 22,99
1 TB 7200 RPM 3.5" Hard Drive
US$ 59,99
Toont producten 1 - 10 van 13
Apparaat Informatie
This rendition is Apple's first desktop machine to feature Intel processing. The Core Duo processor dramatically increased speed, compared to its predecessors. This version is also the first to support screen-spanning without hacks.
Need more memory? Two PC2-5300 1 GB RAM chips will max out your memory at 2 GB. A 2 TB SATA hard drive will top you off.
Select your category below or browse all compatible parts to find what you need to fix your machine!
