PC2-5300 2 GB RAM Chip
  • PC2-5300 2 GB RAM Chip
US$ 14,99
US$ 14,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
A fast 2 GB RAM Chip for laptops
  • RAM is the cheapest and most effective speed upgrade you can do for your computer
  • Faster file save/loading, web browsing, gaming, and more.
  • Check our list of Macs, or your manual to get the right chip style.
Notitie
That "Warranty Void if Removed" sticker is wrong. Feel free to peel that sucker off, we'll still honor our warranty. Our RAM supplier made a mistake in printing, and we're fixing it in our next order of memory.
Compatibiliteit
iMac Intel 17"
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
Mac Mini Model A1176
1.83 GHz (Core 2 Duo, Mid 2007)
2 GHz (Core 2 Duo)
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
2.5 GHz (Penryn)
2.6 GHz (Penryn)
Toon 6 meer apparaten
Reparatieverhalen
Mijn probleem
Macbook was slow.
Mijn oplossing
Couldn’t have been easier!
Mijn advies
The screws are really small and easy to loose. I used a small magnet to keep them in place.
Mijn probleem
The iMac needed a RAM upgrade before it could get Mac OSX 10.11 installed.
Mijn oplossing
The repair went well. A simple screwdriver to remove the cover and then I inserted RAM into the empty slot.
Mijn advies
Removing the memory that was in the computer was difficult. This required a needle-nose pliers or something that can gr . . .
Mijn probleem
Changement de la RAM pour accélération des performances
Mijn oplossing
Très bien.
Mijn advies
Prendre garde pour l'iMac blanc de bien remettre les clapets latéraux des barattes de RAM, avant de remettre les barrettes de RAM en position. Sinon vous ne pourrez plus les ressortir !
Mijn probleem
Someone here was throwing away an iMac because the screen was broken. I picked it and found I could replace the screen for $89. I let the original owner know, but he said it was too old for him. So I ordered some additional memory and an Hybrid SSD 1 TB drive as well. Yeah! I am now windowless at ho . . .
Mijn probleem
The machine only had 1 GB Ram installed
Mijn oplossing
Easy : just follow the guide step by step
Mijn advies
Don't worry, just take your time to follow each step.
Mijn probleem
My harddrive broke so I had to change it.
Mijn oplossing
The repair was REALLY easy and fast! No problems and now my computer is working better than ever because I put more memory in. I also got all my files and programs back because I had made backup with time machine. It was almost too easy:)
Mijn advies
I was taking the comp . . .
Mijn probleem
Old macmini on my shelf
Mijn oplossing
Good repair except I didnt insert the RAM far enough. I just needed to push a bit harder to get it inserted properly.
My suggestion is to recommend to buyers of RAM is to buy two sticks. I had two slots in my mac mini and I only purchased one stick. Now that it's over I wish . . .
Mijn probleem
I had 2 gigs of RAM and needed more speed for my 2008 Mac desktop. A friend of mine that's a whiz with Macs sent me your link. I ordered 2 2GB RAM chips, printed out your directions for installation and it was a snap.
Mijn oplossing
It went without a hitch. It was extremely easy. Thank you!!!!!! Now my computer . . .
Mijn probleem
First time replacing the RAM in a Macbook and thank god! It need it!
Mijn oplossing
It was smooth and simple! Take the battery off then punch out the old and swap with the new.
Mijn advies
Just the usual: discharge any electric charge, disconnect the battery and power source, get to work and get back at it!
Mijn probleem
Yes
Mijn oplossing
Good
Mijn advies
No
Geef meer weer
