MacBook Santa Rosa/Penryn Upper Case with Keyboard
  • MacBook Santa Rosa/Penryn Upper Case with Keyboard / White / New
US$ 119,99
US$ 119,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
Replace a broken or damaged upper case for your 13.3" MacBook with this part (excluding MacBook Unibody and MacBook Air). This part includes the keyboard, palmrest area, trackpad, trackpad cable, and power button.
Notitie
This upper case has been tested and functions in all model A1181 MacBooks, including MacBooks that originally shipped with an upper case with a different function key layout. This upper case can be installed in these early model MacBooks as an upgrade, and all function keys will operate properly.
Compatibiliteit
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Reparatieverhalen
Avatar
Mijn probleem
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
Mijn oplossing
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
Avatar
Mijn probleem
classic cracking in the display bezel and topcase palmrest. Felt like the Mac desirved to be refurbished after the fond college memories
Mijn oplossing
followed the online takeapart guide, was easy as 1 2 3
Mijn advies
make sure to retain the plastic fitting clips when removing the old front bezel frame, they are needed in ord . . .
Avatar
Mijn probleem
era rotta
Mijn oplossing
bene grazie alle istruzioni
Mijn advies
conviene
Avatar
Mijn probleem
Spilled iced tea all over my upper case and my front bezel was showing some age
Mijn oplossing
It went well thanks to the guides
Mijn advies
Diy
Avatar
Mijn probleem
My 7 year old MacBook's keyboard stopped working with many of the keys. Went to the Apple Store. they said for this paticular computer, they did not have the part. Was going to put the MacBook to sleep for good, and decided to tackle changing the keyboard. note| I have zero experience with computer . . .
Avatar
Mijn probleem
Bezel was cracked in assorted places.
The right and left arrow keys quit working.
The trackpad and select (long key below the trackpad) had issues.
Mijn oplossing
I followed the guides and used the plastic bag method to keep track of the screws, at each step I numbered the bag to the step in the instructions. I fou . . .
Avatar
Mijn probleem
Right and Left arrow keys stopped working
The actuator key below the track pad was sticking.
The bezel was cosmetic .
Mac Store wanted almost $400.00 to do the Fix
Mijn oplossing
When I removed the screws with Fixit instructions The some of the screws were in the wrong holes. this unit had been fixed at a
"mac "re . . .
Avatar
Mijn probleem
The letter 'A' came off of the keyboard and would not reseat. My granddaughter needed this MacBook for school.
Mijn oplossing
The repair could not have been easier due to the very detailed disassembly photos along with the text describing the size of each screw. Replacing the top case-keyboard took about an hour . . .
Avatar
Mijn probleem
A of mine client dropped their iPhone 5 and shattered the glass / Another client brought me their MacBook since the display wouldn't show anything if it was opened all the way and only showed the desktop when less then half open.
Mijn oplossing
For the iPhone 5, it was smooth and easier then replacing the display o . . .
Avatar
Mijn probleem
I killed the keyboard with coffee and coffee grounds. It was early morning. I was outside at my wobbly patio table with my MacBook open. I tried to press my coffee, lost the whole pot of morning coffee, and committed keyboard murder at the same time.
Mijn oplossing
I deconstructed the entire machine and cleaned it . . .
Geef meer weer
