MacBook Santa Rosa/Penryn Fan
  • MacBook Santa Rosa/Penryn Fan
US$ 29,99
US$ 29,99
Productdetails
Beschrijving
Beschrijving
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your MacBook Santa Rosa/Penryn model to overheat and eventually damaging your processors. Replace a defective fan to fix overheating problems or to keep your laptop running quietly.
Includes:
  • Fan
  • Surrounding Metal Bracket.
Compatibiliteit
Compatibiliteit
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
Specificaties
Specificaties
Part #:
922-8273
Compatibiliteit
MacBook Core 2 Duo
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
Reparatieverhalen
Gebruikersavatar
Mijn probleem
My daughter's Mac sounded like a lawnmower when it got hot.
Mijn oplossing
Repair was relatively straightforward following the guide on iFixit.
Mijn advies
Some of the steps refer to a #0 Philips but a smaller screwdriver works better. Watch out for the screws behind the memory cover. When replacing, use light pressure to get t . . .
Gebruikersavatar
Mijn probleem
My hard drive finally went up after 8 years. When I opened up my Mac to clean out dust, I noticed my fan seemed off... Considering it went from loud to silent overnight. I tested it and it was also in need of replacement, so I ordered the part.
Mijn oplossing
Easy as pie. The guide is 100% accurate and the screws a . . .
Gebruikersavatar
Mijn probleem
La ventola, oltre a essere rumorosa, iniziava a perdere giri e le temperature salivano troppo; dopo anni di servizio era arrivata al capolinea.
Mijn oplossing
Dopo la sostituzione il computer è tornato silenzioso e le temperature sono nuovamente sotto controllo.
La prima ventola che mi hanno spedito si è rivelata . . .
Gebruikersavatar
Mijn probleem
LAPTOP OVER HEATING AND SHUTTING DOWN, fan not blowing
Mijn oplossing
I ordered part from Ifixit. I had previously replaced my keypad with new one from IFIXIT and directions I found on youtube. So I had and idea on how to disassemble. I took my laptop to a computer repair store, he said not busy at all. Big mistak . . .
Gebruikersavatar
Mijn probleem
The fan in my 2009 Macbook broke down; we went to iCentre here in The Netherlands who claimed the main board broke down; yes, for EUR 1100,- we could replace it. AND .. they had a nice action right that moment for a new Macbook Pro blah blah blah…
Ofcourse we did not go for their stories and w . . .
Gebruikersavatar
Mijn probleem
My MacBook Santa Rosa was heating and the noise of the fan was too loud.
Mijn oplossing
I've change thermal paste and fan with a new one. The fan replacement wasn't necessary, the old one was in good shape. The thermal paste replacement has reduced the heating.
Mijn advies
Do not replace the fan heaven if you think your MacBook . . .
Gebruikersavatar
Mijn probleem
So the problem was not even the fan, it was the inverter, SO while changing the inverter i thought it would be a good idea to clean out the dust in the fan and under the board. Turns out an air compressor at max speed will destroy a macbook fan, so while i was fixing one thing, i broke another, So i . . .
Gebruikersavatar
Mijn probleem
making a loud noise
Mijn oplossing
followed the instructions on the guide and it was very straightforward
Mijn advies
I taped each set of screws onto a piece of printer paper and labeled them as i went, which made them easy to keep track of.
Geef meer weer
