Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery
  • MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery / Fix Kit
  • MacBook Pro 17" Unibody (Early-Late 2011) Replacement Battery / Part Only
  • 360°
360
US$ 99,99
US$ 99,99
We zullen een bericht sturen als het product weer op voorraad is.
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
Productdetails
Beschrijving
Beschrijving
This MacBook Pro 17" Unibody (Early-Late 2011) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 12530 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with Early to Late 2011 MacBook Pro 17" Unibody. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Inhoud van de Kit
Inhoud van de Kit
Compatibiliteit
Compatibiliteit
  • MacBook Pro 17" Unibody A1297 Early 2011 to Late 2011
Specificaties
Specificaties
Model #:
A1383
Watt Hours:
95 Wh
Voltage:
10.95 V
Milliamp Hours:
13190 mAh
Manufacturer:
Aftermarket
Compatibiliteit
A1297 (EMC 2352-1) 2.2 GHz (Early 2011)
A1297 (EMC 2352-1) 2.3 GHz (Early 2011)
A1297 (EMC 2564) 2.4 GHz (Late 2011)
A1297 (EMC 2564) 2.5 GHz (Late 2011)
Klantbeoordelingen
