Repareer je spullen
Recht op reparatie
Winkel
MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery
  • MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery / New / Fix Kit
  • MacBook Pro 17" Unibody (Early 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
US$ 94,99
US$ 94,99
Productdetails
Beschrijving
Beschrijving
This MacBook Pro 17" Unibody (Early 2009-Mid 2010) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 12530 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this replacement battery compatible with MacBook Pro 17" Unibody (Early 2009-Mid 2010). Factory-installed MacBook Pro 17" Unibody (Early 2009-Mid 2010) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Inhoud van de Kit
Inhoud van de Kit
Compatibiliteit
Compatibiliteit
  • MacBook Pro 17" Unibody A1297 Early 2009 to Mid 2010
Specificaties
Specificaties
Part #:
661-5037
Model #:
A1309
Watt Hours:
95 Wh
Voltage:
7.2 V
Milliamp Hours:
13190 mAh
Manufacturer:
Aftermarket
Compatibiliteit
A1297 (EMC 2272) 2.66 GHz (Early 2009)
A1297 (EMC 2272) 2.93 GHz (Early 2009)
A1297 (EMC 2329) 2.8 GHz (Mid 2009)
A1297 (EMC 2329) 3.06 GHz (Mid 2009)
A1297 (EMC 2352) 2.53 GHz (Mid 2010)
A1297 (EMC 2352) 2.66 GHz (Mid 2010)
A1297 (EMC 2352) 2.8 GHz (Mid 2010)
Klantbeoordelingen
