Repareer je spullen
Recht op reparatie
Winkel
MacBook Pro 17" Battery
  • MacBook Pro 17" Battery
  • 360°
360
US$ 59,99
US$ 59,99
Productdetails
Beschrijving
Beschrijving
This MacBook Pro 17" replacement battery is what you need to bring your dead laptop back to life!
  • High quality replacement battery that uses battery cells manufactured by Samsung.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with all 17" MacBook Pros (excluding Unibody). Factory-installed MacBook Pro (non-Unibody) batteries are rated to last 300 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 17" up to Late 2008
  • Model A1151, A1212, A1229, A1261
Specificaties
Specificaties
Part #:
661-3974
Model #:
A1189
Watt Hours:
71 Wh
Voltage:
10.8 V
Milliamp Hours:
6480 mAh
Manufacturer:
Aftermarket
Compatibiliteit
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
A1151 (EMC 2102) 2.16 GHz (Core Duo)
A1212 2.33 GHz (Core 2 Duo)
A1229 (EMC 2137) 2.4 GHz (Santa Rosa)
A1229 (EMC 2137) 2.6 GHz (Santa Rosa)
A1261 (EMC 2199) 2.5 GHz (Penryn)
A1261 (EMC 2199) 2.6 GHz (Penryn)
Klantbeoordelingen
