Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Replacement Battery
  • MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Replacement Battery / Fix Kit
  • MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
US$ 94,99
US$ 94,99
We zullen een bericht sturen als het product weer op voorraad is.
Nintendo Switch-kits
Een snelle oplossing die je weer mee laat doen
Koop Switchkits
Koop Switchkits
Productdetails
Beschrijving
Beschrijving
This MacBook Pro 15" Unibody (Mid 2009-Mid 2010) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6730 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this new replacement battery compatible with MacBook Pro 15" Unibody (Mid 2009-Mid 2010). Factory-installed MacBook Pro 15" Unibody (Mid 2009-Mid 2010) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Inhoud van de Kit
Inhoud van de Kit
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Mid 2009 to Mid 2010
Specificaties
Specificaties
Part #:
661-5211
Model #:
A1321
Watt Hours:
77.5 Wh
Voltage:
10.95 V
Milliamp Hours:
7080 mAh
Manufacturer:
Aftermarket
Compatibiliteit
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
A1286 (EMC 2324) 2.53 GHz
MacBook Pro 15" Unibody Mid 2009
A1286 (EMC 2325) 2.66 GHz
A1286 (EMC 2325) 2.8 GHz
A1286 (EMC 2325) 3.06 GHz
MacBook Pro 15" Unibody Mid 2010
A1286 (EMC 2353) 2.4 GHz
A1286 (EMC 2353) 2.53 GHz
A1286 (EMC 2353) 2.66 GHz
A1286 (EMC 2353) 2.8 GHz
Klantbeoordelingen
