Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
MacBook Pro 15" Unibody (Late 2008-Late 2011) LCD Panel
  • MacBook Pro 15" Unibody (Late 2008-Late 2011) LCD Panel
US$ 84,99
US$ 84,99
We zullen een bericht sturen als het product weer op voorraad is.
Manta schroevendraaierset
112 bits for every fix.
Upgrade Your Toolbox
Productdetails
Beschrijving
Beschrijving
Replacement display panel for 15.4" Unibody displays. Compatible with all 15" Unibody MacBook Pros. 15.4” screen.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Late 2008 to Late 2011
Specificaties
Specificaties
Part #:
LP154WP3-TLA3, LP154WP4-TLA1
Size:
15.4"
Resolution:
Standard: 1440x900
High: 1680x1050
Compatibiliteit
MacBook Pro 15" Unibody 2.53 GHz Mid 2009
A1286 (EMC 2324) 2.53 GHz
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.66 GHz
2.93 GHz
A1286 (EMC 2255) 2.4 GHz
A1286 (EMC 2255) 2.53 GHz
A1286 (EMC 2255) 2.8 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2009
A1286 (EMC 2325) 2.66 GHz
A1286 (EMC 2325) 2.8 GHz
A1286 (EMC 2325) 3.06 GHz
MacBook Pro 15" Unibody Mid 2010
A1286 (EMC 2353) 2.4 GHz
A1286 (EMC 2353) 2.53 GHz
A1286 (EMC 2353) 2.66 GHz
A1286 (EMC 2353) 2.8 GHz
Toon 3 meer apparaten
Reparatieverhalen
Gebruikersavatar
patrash's Story Photo #229687
patrash's Story Photo #229688
Mijn probleem
LCD on MacBookPro was damaged and didn´t work properly
Mijn oplossing
Like a charm!
It was a bit hard no exactly know how much heating had to be done to ensure that display glam could be removed from adhesive edge around the display. I think I accidently heated it too much and a huall area of the glam became a bi . . .
Gebruikersavatar
Mijn probleem
My lcd was bad
Mijn oplossing
As many others have said, getting the glass off was real tough, I found that when I wasn't having success in one corner, I tried a lower corner and it worked much better. From there I just pried all the way around, making sure to heat a bit as I went.
Mijn advies
I bought my led from Ifixit and the . . .
Gebruikersavatar
Mijn probleem
I always try to fix things myself, and my wifes laptop screen was not going to be an exception.
Mijn oplossing
Easy! Simple! Step by step instructions that even a monkey can learn to follow. This was my first time ever working on electronics, so it was a bit intimidating at first, but very easy. The parts i ordered . . .
Gebruikersavatar
Mijn probleem
Back of aluminum had something fall on it and dented right into the lcd , and broke it.
Mijn oplossing
Very well , easy followed instructions did it in just under an hour for disassembling . Part arrived the next day put it in and reassembled in less time .
I had to drill out some stripped screws .. No big deal . . . .
Gebruikersavatar
Mijn probleem
Il mio schermo LCD é morto ,fuori garanzia ovviamente costo riparazione 600 euro e più. Dopo aver messo del disossidante per contatti sul connettore dello schermo ha ricominciato a funzionare , peccato che abbia rovinato lo schermo
Mijn oplossing
Riparazione avvenuta con successo, a parte gli insetti dentro lo sc . . .
Gebruikersavatar
Mijn probleem
Screen was smashed so I had to fix it
Mijn oplossing
This was not easy, but definitely worth the work. The instructions on this website are superb
Mijn advies
Make sure to keep track of which screws go where!
Gebruikersavatar
Mijn probleem
Lcd was broken, its cheaper do it by yourself
Mijn oplossing
LCD was replaced flawlessly... the front glass didnt had the same fate.
Mijn advies
remove the front glass is very tricky, better consider have a spare front glass handy
Gebruikersavatar
Mijn probleem
Broken LCD w/ verticle bands of solid white/black.
Mijn oplossing
Reasonably well. Used a hair dryer instead of a heat gun. Had a lot of trouble getting LVDS cable (also replaced) to stay in the lcd when putting everything back together.
Mijn advies
My LCD panel has about 50 stuck red pixels all in a clump in the lower left cor . . .
Gebruikersavatar
Mijn probleem
My mac took a bit of a tumble and the bottom quarter of the screen was distorted to just lines. Took it into to an Apple store to make sure it was the right problem and see if it would at least be around the same price as fixing it myself, but ~$500 was a little pricey for me.
Mijn oplossing
I only had two issues c . . .
Gebruikersavatar
Mijn probleem
The late-2008 Macbook Pro 15" - after a lightning discharged quite nearby the screen acquired a bad habit of turning white washed out. Could be a coincidence or just a factor promoting a defect.
The washout could be remedied by a little pinching of the screen - so it was just a matter of time the g . . .
Geef meer weer
