Repareer je spullen
Recht op reparatie
Winkel
MacBook Pro 15" Unibody (Late 2008-Early 2009) Replacement Battery
  • MacBook Pro 15" Unibody (Late 2008-Early 2009) Replacement Battery
  • 360°
360
US$ 99,99
US$ 99,99
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Koop iPhone-reparatiekits
SLA DE UPGRADE OVER
Productdetails
Beschrijving
Beschrijving
This MacBook Pro 15" Unibody (Late 2008-Early 2009) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4940 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with Late 2008 to Early 2009 MacBook Pro 15" Unibody. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Late 2008 to Early 2009
Specificaties
Specificaties
Part #:
661-4833
Model #:
A1281
Watt Hours:
50 Wh
Voltage:
10.8 V
Milliamp Hours:
5200 mAh
Manufacturer:
Aftermarket
Compatibiliteit
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.66 GHz
2.93 GHz
A1286 (EMC 2255) 2.4 GHz
A1286 (EMC 2255) 2.53 GHz
A1286 (EMC 2255) 2.8 GHz
Klantbeoordelingen
