MacBook Pro 15" Unibody (Late 2008-Early 2009) Access Door
  • MacBook Pro 15" Unibody (Late 2008-Early 2009) Access Door
US$ 49,99
US$ 49,99
Productdetails
Beschrijving
Beschrijving
Replace a scratched or dented aluminum lower case battery access panel.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Late 2008 to Early 2009
Specificaties
Specificaties
Part #:
922-8710
Compatibiliteit
MacBook Pro 15" Unibody Late 2008 & Early 2009
2.66 GHz
2.93 GHz
A1286 (EMC 2255) 2.4 GHz
A1286 (EMC 2255) 2.53 GHz
A1286 (EMC 2255) 2.8 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
Opened the battery door too many times with checking alignment so that latches were bent so it won't close properly.
Mijn oplossing
Tried to bend back the latches several time but eventually the latches broke so I ordered a replacement from iFixit
Mijn advies
Ensure you alignment of the battery door and the case.
Gebruikersavatar
mcoletta's Story Photo #227005
mcoletta's Story Photo #227004
Mijn probleem
Due to a battery malfunction ( became bigger) I lost access door
Mijn oplossing
Perfect !
Mijn advies
Be careful of yr battery status !!!!!
