Repareer je spullen
Recht op reparatie
Winkel
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
  • MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
US$ 299,99
US$ 299,99
De essentiële toolkit
De meest behulpzame tools in onze meest compacte kit.
Koop nu
Koop nu
Productdetails
Beschrijving
Beschrijving
Replace a broken or damaged upper case, backlit keyboard, and battery level indicator assembly compatible with the Early 2011 to Mid 2012 MacBook Pro 15" Unibody laptop.
De assemblage bevat
De assemblage bevat
  • Upper Case
  • Backlit Keyboard
  • Battery Level Indicator
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Early 2011 to Mid 2012
Specificaties
Specificaties
Part #:
661-5854, 661-6076
Compatibiliteit
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
MacBook Pro 15" Unibody Mid 2012
A1286 (EMC 2556) 2.3 GHz
A1286 (EMC 2556) 2.6 GHz
A1286 (EMC 2556) 2.7 GHz
Reparatieverhalen
Gebruikersavatar
kennyfoner's Story Photo #246171
Mijn probleem
Gebruikersavatar
Mijn probleem
The keyboard had keys that weren't working.
Mijn oplossing
Thanks to the repair guide, the repair went very smoothly.
Mijn advies
1. Print out the guide and number little plastic baggies with the step number screws and small parts.
2. The trackpad connect/disconnect seemed to be missing, look it up on YouTube.
3. Take you . . .
Gebruikersavatar
Mijn probleem
Coffee everywhere.
Mijn oplossing
Flawless. Took about 1.5 hours. I had already had this thing apart a few times so I felt like an expert... probably would have taken longer otherwise.
Mijn advies
- An empty icecube tray with post-it notes is a great way to keep track of screws and small parts along the way.
- Photos are a goo . . .
Gebruikersavatar
Mijn probleem
My son spilled a glass of water on my wife's 2011 early macbook pro. The keyboard and trackpad no longer behaved properly
Mijn oplossing
The repair took a long time. It was difficult. But in the end it was successful.
Mijn advies
Take your time. It is a good idea to have an egg carton or ice tray (or two) to keep screws sorted . . .
Gebruikersavatar
Mijn probleem
A client called with an issue.. "I spilled a DR Pepper on my my Macbook Pro *last week* and the keyboard stopped working. I used it with an external but now I get nothing." So, it's iFixit to the rescue. I searched for a replacement but all the pieces separate were just outrageous, but iFixit had it . . .
Gebruikersavatar
Mijn probleem
Well the wife forgot the Mac was nearby while watering a plant and that was all it took. She didn't turn it off and tried to shake the water out. I let it sit for a few day after getting the water out of it, but the keyboard was toast.
Mijn oplossing
All went pretty much according to the guide. The display cable wa . . .
Gebruikersavatar
Mijn probleem
I spilled wine on my laptop keyboard. It worked fine initially, but by the next morning, keys would not function and it became impossible to use. Not wanting to buy a new machine or send off the computer to Apple for an expensive repair, I bought the parts and tools straight from iFixit. I found . . .
Gebruikersavatar
Mijn probleem
My MacBook Pro's upper case didn't look to good, after it fell like 1 meter. The internal parts survived the drop without any damage - yay!
Mijn oplossing
Definitely not an easy repair. The repair took me more than an hour.
Mijn advies
You'll need a good brain or some sort of system to know, where which screw goes...
Gebruikersavatar
Mijn probleem
I spilled coffee over keyboard. So the keyboard didn't work anymore.
Mijn oplossing
With the instruction on ifixit website, it was quite easy and nothing complicated. Just needed proper tools and took time for me. Because it was the first time that I repair my computer by myself.
Mijn advies
The most difficult part for me was t . . .
Gebruikersavatar
Mijn probleem
I spilled a soda all over my laptop. After drying it out, the only problem was the keyboard no longer worked correctly. Very sticky keys.
Mijn oplossing
It was great. Followed the directions to a tee. Worked perfectly.
Mijn advies
GET THE TOOLS... Tried to take apart some of this with my own tools and stripped two screws.. . . .
Geef meer weer
