Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
  • MacBook Pro 15" Unibody (Early 2011-Late 2011) Display Assembly
US$ 149,99
US$ 149,99
We zullen een bericht sturen als het product weer op voorraad is.
Manta schroevendraaierset
112 bitjes voor elke reparatie.
Upgrade Your Toolbox
Productdetails
Beschrijving
Beschrijving
Replace a broken or damaged display assembly compatible with your Early 2011-Late 2011 MacBook Pro 15" Unibody laptop.
Includes the LCD screen, display cover, bezel, FaceTime HD camera, clutch hinges, Wi-Fi antenna, camera, and display data cables.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Early 2011 to Late 2011
Specificaties
Specificaties
Part #:
661-5847
Size:
15.4"
Compatibiliteit
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
Bought a macbook pro as a refurbished device with a Matt screen, and the colors where washed out.
Mijn oplossing
Pretty easy
Mijn advies
When putting the new screen in the alignment for the hinges are a little bit tricky just some patience and you'll be golden
Gebruikersavatar
Mijn probleem
Screen glass, display and top cover damaged due hard object dropping onto my wife's computer when in closed position.
Mijn oplossing
Repair went OK until having to remove cable display data cable retainer from the upper case. The retaining screw could not be removed however hard I tried - the result being that th . . .
