MacBook Pro 15" Unibody (Early 2011) 2.2 GHz Logic Board
  • MacBook Pro 15" Unibody (Early 2011) 2.2 GHz Logic Board
US$ 169,99
US$ 169,99
Productdetails
Beschrijving
Beschrijving
Replace th 2.2 GHze logic board in your MacBook Pro 15" Unibody (Early 2011) and fix processing issues.
  • Included Ports: Thunderbolt (Mini DisplayPort), 1000BaseT Ethernet, Firewire 800, 2 USB 2.0, SD card slot, Audio In, Audio Out.
A corroded, malfunctioning, or water-damaged logic board can cause unexpected shutdowns or reboots. Restore the functionality of your device with this replacement part.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" Unibody A1286 Early 2011 to Late 2011
Specificaties
Specificaties
Part #:
661-5852, 661-6081
Speed:
2.2 GHz
GPU:
Dual graphics with automatic graphics switching:
Intel HD Graphics 3000 (384 MB shared)
AMD Radeon HD 6750M (1 GB dedicated)
Compatibiliteit
MacBook Pro 15" Unibody Early 2011
A1286 (EMC 2353-1) 2 GHz
A1286 (EMC 2353-1) 2.2 GHz
A1286 (EMC 2353-1) 2.3 GHz
MacBook Pro 15" Unibody Late 2011
A1286 (EMC 2563) 2.2 GHz
A1286 (EMC 2563) 2.4 GHz
A1286 (EMC 2563) 2.5 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
The logic board was finished and simply required replacement. At first, I thought it was the graphic card because there were green and grey lines on the screen. However when the MacBook did restart as it should, Apple confirmed the problem.
Mijn oplossing
The repair was smooth. I gave it to the right people and . . .
