MacBook Pro 15" (Model A1150) Left Fan
  • MacBook Pro 15" (Model A1150) Left Fan
US$ 29,99
US$ 29,99
We zullen een bericht sturen als het product weer op voorraad is.
Productdetails
Beschrijving
Beschrijving
Replace a malfunctioning or noisy fan compatible with a Model A1150 15" MacBook Pro.
If your screen is facing you, this is the fan on the left side of the machine nearest the AirPort Express card.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" A1150
Specificaties
Specificaties
Part #:
922-7193
Compatibiliteit
Reparatieverhalen
Avatar
Mijn probleem
The left fan started making noise constantly.
Mijn oplossing
The repair went pretty smoothly. One of the metal tabs on the case broke off so that case screw couldn't go back in and another case screw just wouldn't go back without stripping. Also, took several tries to get the top back on the case. The tabs just . . .
Avatar
Mijn probleem
The computer was overheating and began making a noise.
Mijn oplossing
The repair went excellently. To be honest this wasn't the first time I had had to perform surgery on this Macbook. A few years ago I had replaced the hard drive so I was already familiar with disassembling the computer and had the correct tools.
Mijn advies
T . . .
Avatar
Mijn probleem
The fan died.
Mijn oplossing
Excellent! The photo tutorial walked me thru the process and I had no issues.
Mijn advies
Keep doing what you're doing, I'll be back when I have to make my next repair.
Avatar
Mijn probleem
the fan began to make so much noise, i installed the software smcfan to saw whats was going on and i realized the left fan was dead 0 rpm
Mijn oplossing
perfect, i printed the guide and step by step i changed the fan, so easy
Mijn advies
Only be carefull by pulling the plugs, better use the Spudger if you can.
When remove the . . .
Avatar
Mijn probleem
The fan in my Macbook pro was creating a lot of noise. I needed to replace it.
Mijn oplossing
It went well. It was a little scary but I was successful.
Mijn advies
Step 12 of the instructions was not as specific as I would have liked. I ultimately figured out how to do it but I was worried that I might be causing harm to my sys . . .
Avatar
Mijn probleem
I replace my optical drive with a SSD.
Mijn oplossing
The installation was easy, no problem.
But when I install the OS on the SSD and boot from it, I can no longer enter sleep mode. I've tried to google the problem but have found nothing about that kind of behaviour. Anyone got a suggestion?
Mijn advies
Nope, installation was . . .
Avatar
Mijn probleem
A customer left a Macbook Pro with a faulty left fan. I went to ifixit.com for ordering not for being the cheapest on the market but for ideological reasons. Help the ones helping me!
Mijn oplossing
Did work great then checking the super guide at ifixit.com
Mijn advies
Take it easy with Apple brand parts.
Avatar
Mijn probleem
My right fan was dead, never showed as running when I checked istat pro. Led to my mac running hotter than it should. Figured I would replace both since I already had to open it for the one.
Mijn oplossing
The only complaint was UPS delivered my fans a day late when I paid for next day air. The only difficult part . . .
Avatar
Mijn probleem
My old fellow (A MBP 2006) started to be noisy. The left fan was making a sound like a blender at top speed.
Mijn oplossing
The guide was incredibly helpful, the problems start when I tried to open the upper case, I broke some parts of it (Where you put the screws). Then I realized that some tapes where put on pla . . .
Avatar
Mijn probleem
Damaged and noisy fan.
Mijn oplossing
It took about 45 minutes. The guide was very helpful. It was kind of hard taking the keyboard on and off, but I am pretty dumb when it comes to computers. I damaged a piece putting the keyboard back on, but it doesn't affect the performance of my computer. After replacing the f . . .
Geef meer weer
