Repareer je spullen
Recht op reparatie
Winkel
MacBook Pro 15" Battery
  • MacBook Pro 15" Battery
  • 360°
360
US$ 59,99
US$ 59,99
Productdetails
Beschrijving
Beschrijving
This MacBook Pro 15" replacement battery is what you need to bring your dead laptop back to life!
  • High quality replacement battery that uses battery cells manufactured by Samsung.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this new replacement battery compatible with 15 inch MacBook Pro models (excluding Unibody). Factory-installed MacBook Pro (non-Unibody) batteries are rated to last 300 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Compatibiliteit
Compatibiliteit
  • MacBook Pro 15" A1150, A1211, A1226, A1260
Specificaties
Specificaties
Part #:
661-3864
Watt Hours:
60 Wh
Voltage:
10.8 V
Milliamp Hours:
5550 mAh
Manufacturer:
Aftermarket
Compatibiliteit
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
MacBook Pro 15" Core 2 Duo Models A1226 & A1260
A1226 (EMC 2136) 2.2 GHz (Santa Rosa)
A1226 (EMC 2136) 2.4 GHz (Santa Rosa)
A1226 (EMC 2136) 2.6 GHz (Santa Rosa)
A1260 (EMC 2198) 2.4 GHz (Penryn)
A1260 (EMC 2198) 2.5 GHz (Penryn)
A1260 (EMC 2198) 2.6 GHz (Penryn)
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Klantbeoordelingen
