MacBook Pro 15" (Non-Unibody) Memory Maxxer Kits
Grab a toolkit for your MacBook Pro 15" (Non-Unibody) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Kies je model van MacBook Pro 15" (Non-Unibody):
Onderdelen compatibel met MacBook Pro 15" (Non-Unibody):
MacBook Pro 15" Model A1226 Memory Maxxer RAM Upgrade Kit
Max your MacBook Pro 15" Model A1226 with 6 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your laptop. Compatible with 2.2, 2.4, or 2.6 GHz Core 2...
MacBook Pro 15" Model A1260 Memory Maxxer RAM Upgrade Kit
Max your MacBook Pro 15" Model A1260 with 6 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your laptop. Compatible with 2.2, 2.5, or 2.6 GHz Core 2...
MacBook Pro 15" Model A1150 Memory Maxxer RAM Upgrade Kit
Max your MacBook Pro 15" Model A1150 with 2 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your laptop. Compatible with 1.83, 2.0, or 2.16 GHz Core...
MacBook Pro 15" Model A1211 Memory Maxxer RAM Upgrade Kit
Max your MacBook Pro 15" Model A1211 with 4 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your laptop. Compatible with 2.16 or 2.33 GHz Core 2 Duo...
Apparaat Informatie
The MacBook Pro 15" replaced the Aluminum 15" and features Intel support and an integrated iSight camera.
All MacBook Pro 15" Non-Unibody models use PC2-5300 RAM. Two RAM slots means an easy memory upgrade! If storage is an issue, any 9.5mm SATA hard drive will expand your boundaries.
Heat has always been an issue for MacBook Pros. It's possible that a bad thermal sensor or fan will prevent the machine from booting.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Non-Unibody repair guides for step-by-step instructions on how to make the fix.
