MacBook Pro 15" Touch Bar Mid 2018 Case Components
Grab a toolkit for your MacBook Pro 15" Touch Bar Mid 2018 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Onderdelen compatibel met MacBook Pro 15" Touch Bar Mid 2018:
MacBook Pro 15" Retina (Late 2016-2019) Trackpad
Replace a damaged or malfunctioning trackpad compatible with a Late 2016 to 2019 model MacBook Pro 15" with Retina Display and Touch Bar.
MacBook Pro 15" Retina (Mid 2018-2019) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
MacBook Pro 15" Retina (Mid 2018-2019) Upper Case Assembly
Replace an upper case, keyboard, and battery compatible with the 2018 and 2019 model A1990 MacBook Pro 15 inch Retina laptop.
MacBook Pro 15" Retina (Mid 2018-2019) Microphone Cable Bracket
Replace a bent or missing metal bracket securing the microphone cable connector to the logic board in a 2018 to 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 15" Retina (Mid 2018-2019) Hinge Covers
Replace the plastic covers for the display hinges.
MacBook Pro 15" Retina (Mid 2018-2019) Headphone Jack Cable Bracket
Replace a bent or missing bracket securing the headphone jack cable connector to the logic board in a 2018 or 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 15" Retina (Mid 2018-2019) Display Cable Bracket
Replace bent or missing metal brackets securing the display cable in a 2018 or 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 15" Retina (Late 2016-2019) Lower Case
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 15" Retina (Mid 2018-2019) Trackpad and Keyboard Cable Bracket
Replace the metal bracket that holds the trackpad cable and keyboard cable connectors in place on the logic board compatible with the Mid 2018 to 2019 15 inch model A1990...
MacBook Pro 15" Retina (Mid 2018-2019) USB-C Cable Brackets
Replace bent or missing brackets that secure the two USB-C cable connectors to the logic board in a 2018 or 2019 model 15" MacBook Pro with Retina Display.
Apparaat Informatie
Released in July 2018 as model A1989, this MacBook Pro features Coffee Lake processors up to the 2.9GHz Intel Core i9 processor with Turbo Boost up to 4.8 GHz.
The most common repairs with the 15" MacBook Pro Retina Mid 2018 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2018 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 15" Mid 2018 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2018 repair guides for step-by-step instructions on how to make the fix.
