MacBook Pro 15" Model A1260 Display Components
Grab a toolkit for your MacBook Pro 15" Model A1260 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Onderdelen compatibel met MacBook Pro 15" Model A1260:
MacBook Pro 15" (Models A1226/A1260) LED Driver Board
LED Driver Board controls the LED backlight.
MacBook Pro 15" (Models A1226/A1260) Inverter/iSight Cable
MacBook Pro 15" (Model A1260) AirPort Antenna Cables
Antenna cables and the assembly that rests inside the antenna cover.
MacBook Pro 15" (Models A1211/A1226/A1260) Antenna Cover
Houses the AirPort antenna cable assembly within the clutch cover.
MacBook Pro 15" (Models A1226/A1260) Clutch Cover
Houses the hinges and airport antenna assembly.
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
Apparaat Informatie
The model A1260 MacBook Pro 15" included an LED-backlit display, and the Santa Rosa processor architecture resulted in a faster bus speed and a graphics upgrade.
The most common repairs with the model A1260 15" MacBook Pro are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Model A1260 Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 6 GB of RAM.
Once you've bought your parts and tools, check out iFixit's A1260 MacBook Pro 15" repair guides for step-by-step instructions on how to make the fix.
