MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable
  • MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable / New / With Bracket
  • MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable / Used / With Bracket
  • MacBook Pro 13" Unibody (Early 2011-Late 2011) Hard Drive Cable / Used / Without Bracket
  • 360°
360
US$ 44,99
US$ 44,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
Replace a damaged hard drive cable in your Early-Late 2011 MacBook Pro 13" Unibody laptop computer with this part to fix the connection of an unrecognized drive.
Notitie
May include optional set of 5 rubber strips that provide additional protection during jostling and movement of the hard drive/computer.
Reparatieverhalen
Avatar
Mijn probleem
The mac could not see the hard drive and we had just replaced it with a stateless drive.
Mijn oplossing
The repair went great as my son followed a short explanation video online. Took only 25 minutes or so and saved a TON like $75.00.
Mijn advies
Just make sure you are ordering the correct part. We did our research and got expe . . .
Avatar
Mijn probleem
I've run into this problem a bunch of times across several MBPs. I don't know why I keep running into faulty SATA cables, but at this point I'm a pro at replacing them.
Mijn oplossing
The repair went well, but the cable has failed again. I'm not looking at other vendors for a different cable.
Mijn advies
The repair is very eas . . .
Avatar
Mijn probleem
Mac didn't boot, couldn't find the drive, a new-ish SSD I had installed previously. Sure enough, when plugged into another computer, the drive showed up, leading me to believe the culprit was the cable.
Mijn oplossing
Easy, remove back plate, remove old cable, slap in new cable, screw on back plate. Realize the you . . .
Avatar
Mijn probleem
Computer would not boot - showed file folder with X.
Mijn oplossing
Instructions were well written with pictures. Most difficult task was reinstalling Hard Drive Cable hold down screws.
Mijn advies
None needed.
Avatar
Mijn probleem
My cable connecting the harddrive to the computer was faulty. But I didn’t know that. All I saw was a folder with a question mark flashing on my screen. Fortunately or unfortunately, this happened twice before so I knew what I had to do (or hoped I was correct).
Mijn oplossing
I ordered the device. It came on tim . . .
Avatar
Mijn probleem
My computer crashed and without any knowledge I was up a creek without a paddle. However I went to the Apple store so they could run a diagnostic on my computer. The gentleman that helped me suggested I go through ifixit.com in order to solve my problem. Thankfully the crashed computer wasn't anythi . . .
Avatar
Mijn probleem
Harddrive cable fix.
Mijn oplossing
The repair was quite easy because I fixed it before.
Mijn advies
The only advice is to make sure you disconnect the battery cable just in case power goes through while you're fixing any wires and dont want to short circuit any other wiring.
Avatar
Mijn probleem
The computer would no longer boot and came up with a folder with a question mark in it.
Mijn oplossing
The repair was not hard, but a little tedious getting the ribbon cable in place and making the 90 degree bends and sticking it to the bottom of the hard drive area. It was difficult to place the hard drive back i . . .
Avatar
Mijn probleem
My laptop is in very good condition, but for this one fault.
Mijn oplossing
I didn't do the repair, but the man who did said the instructions were excellent and that it all went smoothly.
Mijn advies
Not really!
Avatar
Mijn probleem
The computer refused to boot with the familiar folder with the? in the middle. This was obviously a bad hard drive right - NOT! OK motherboard right, no. This is tricky to diagnose in that you have to physically remove the hard drive, not a problem on the 2012 MacBook Pro. Drive OK motherboard . . .
Geef meer weer
