Onderdelen Mac MacBook Pro 13" Unibody Mid 2012 Hard Drives SATA
Winkel
Weet u het type niet? Identificeer je Mac
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Fix Kit
Replace a dead or dying battery compatible with a 13" Unibody MacBook Pro laptop.
Van US$ 44,99
MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable / With Bracket / New
This cable connects the hard drive to the logic board.
Van US$ 9,99
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
Van US$ 4,99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$ 8,99
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
Van US$ 9,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$ 7,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
Van US$ 89,99
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Trackpad
Replace a scratched or malfunctioning trackpad in your 13” Unibody MacBook Pro.
Van US$ 59,99
MacBook Pro Unibody (A1278) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and power button switch compatible with a mid 2009 to mid 2012 A1278 model 13" MacBook Pro Unibody laptop.
US$ 19,99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
Van US$ 14,99
Toont producten 1 - 10 van 52
Apparaat Informatie
The Mid 2012 version of MacBook Pro 13" Unibody is virtually identical to the Late 2011 model with a CPU and graphics upgrade. It features an Ivy Bridge quad core Core i7 processor with PC3-12800 RAM. In addition to the Thunderbolt port and SDXC card slot it now features two USB 3 ports.
The most common repairs with the MacBook Pro 13" Unibody for Mid 2012 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Mid 2012) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The MacBook Pro 13" Unibody for Mid 2012 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Mid 2012 repair guides for step-by-step instructions on how to make the fix.
