MacBook Pro 13" Retina Logic Boards
Grab a toolkit for your MacBook Pro 13" Retina model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Kies je model van MacBook Pro 13" Retina:
Onderdelen compatibel met MacBook Pro 13" Retina:
MacBook Pro 13" Retina (Late 2013) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Late 2013 MacBook Pro 13" laptop. Includes 4, 8, or 16 GB RAM. Fix processing issues like unexpected shutd...
MacBook Pro 13" Retina (Early 2015) 2.7 GHz Logic Board
Replace a 2.7 GHz logic board (motherboard) compatible with the Early 2015 MacBook Pro 13" model laptop. Includes 8 GB or 16 GB RAM. Fix processing issues like unexpected...
MacBook Pro 13" Retina (Mid 2014) 2.6 GHz Logic Board
Replace a broken or damaged 2.6 GHz logic board in your Mid 2014 MacBook Pro 13" with this part.
MacBook Pro 13" Retina (Mid 2014) 2.8 GHz Logic Board
Replace a 2.8 GHz logic board (motherboard) compatible with the Mid 2014 MacBook Pro 13" laptop. Includes 8 or 16 GB of RAM. Fix processing issues like unexpected shutdow...
MacBook Pro 13" Retina (Mid 2014) 3.0 GHz Logic Board
Replace a 3.0 GHz Core i7 logic board (motherboard) compatible with the Mid 2014 MacBook Pro 13" Retina laptop. Included Ports: 2 Thunderbolt (Mini Display Port), one HDM...
MacBook Pro 13" Retina (Touch Bar, 2017) 3.1 GHz Logic Board with Paired Touch ID Sensor
Replace a 3.1 GHz Core i5 logic board (motherboard) compatible with the Touch Bar 2017 MacBook Pro 13" Retina laptop. Includes RAM, SSD, and paired Touch ID Sensor. Fix p...
MacBook Pro 13" Retina (Late 2013) 2.8 GHz Logic Board
Replace a 2.8 GHz Core i7 logic board (motherboard) compatible with the Late 2013 MacBook Pro 13" Retina laptop. Includes 4, 8, and 16 GB RAM. Included ports: 2 Thunderbo...
MacBook Pro 13" Retina (Touch Bar, Late 2016) 3.1 GHz Logic Board with Paired Touch ID Sensor
Replace a 3.1 GHz Core i5 logic board (motherboard) compatible with the Late 2016 Touch Bar model MacBook Pro 13" Retina laptop. Includes RAM, SSD, and paired Touch ID se...
MacBook Pro 13" Retina (Mid 2018) 2.3 GHz Logic Board with Paired Touch ID Sensor
Replace a 2.3 GHz Core i5 logic board (motherboard) compatible with the Mid 2018 MacBook Pro 13" Retina laptop. Includes RAM, SSD, and Touch ID sensor. Fix processing iss...
MacBook Pro 13" Retina (Function Keys, Late 2016) 2.4 GHz Logic Board
Replace a 2.4 GHz Core i7 logic board (motherboard) compatible with the Late 2016 Function Keys MacBook Pro 13" Retina laptop. Includes 8 GB or 16 GB RAM. Fix processing ...
Apparaat Informatie
Late in 2012 Apple released the MacBook Pro 13" with a new Retina display having 2560-by-1600 resolution. The Retina Display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 13" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display repair guides for step-by-step instructions on how to make the fix.
