MacBook Pro 13" Retina Headphone Jacks
Grab a toolkit for your MacBook Pro 13" Retina model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Kies je model van MacBook Pro 13" Retina:
Onderdelen compatibel met MacBook Pro 13" Retina:
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Headphone Jack
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2016 or 2017 model 13" MacBook Pro with Retina Display and Touch Bar.
MacBook Pro 13" Retina (Function Keys, Late 2016-2017) Headphone Jack
Replace a damaged or corroded 3.5 mm audio jack or a malfunctioning microphone in a 2016 or 2017 model 13" MacBook Pro with Retina Display and function keys.
Replace a dirty, corroded, or damaged 3.5 mm headphone jack in a 13" MacBook Pro with Retina Display.
MacBook Pro 13" Retina (Mid 2018-2020) Headphone Jack
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2018 or 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" (A2289, 2020) Headphone Jack
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2020 model A2289 13" MacBook Pro with two Thunderbolt ports.
MacBook Pro 13" (A2159, 2019) Headphone Jack
Replace a damaged or corroded the 3.5 mm audio jack compatible with a 2019 model A2159 13" MacBook Pro with two Thunderbolt ports.
Apparaat Informatie
Late in 2012 Apple released the MacBook Pro 13" with a new Retina display having 2560-by-1600 resolution. The Retina Display models that followed the 2012 model vary by specifications and features.
The most common repairs with the 13" MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly. Choose a model for more specific information.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display repair guides for step-by-step instructions on how to make the fix.
