Repareer je spullen
Recht op reparatie
Winkel
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Retina Mid 2014 Heat Sinks
Winkel
Grab a toolkit for your MacBook Pro 13" Retina Mid 2014 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Weet u het type niet? Identificeer je Mac
Apparaat Informatie
On July 29, 2014 Apple introduced a new 13" MacBook Pro with Retina Display. Externally, this "Mid 2014" model looks very much like the "Late 2013" model. The 13.3" widescreen 2560x1600 (227 ppi) display, external ports, and Wi-Fi capabilities are unchanged. The Mid 2014 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 and Late 2013 models, this machine has no Ethernet or Firewire ports, although adapters are available. Internally, the Mid 2014 model features faster processors and 8 or 16 GB of RAM that cannot be upgraded after purchase.
The most common repairs with the 13" Mid 2014 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Mid 2014 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Mid 2014 repair guides for step-by-step instructions on how to make the fix.
