Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Retina Late 2013 Rubber Feet
Winkel
Grab a toolkit for your MacBook Pro 13" Retina Late 2013 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Weet u het type niet? Identificeer je Mac
Apparaat Informatie
On October 22, 2013 Apple introduced a new 13" MacBook Pro with Retina Display. Externally, this "Late 2013" model looks very much like the "Early 2013" model, but the new case is slightly thinner and the weight has been trimmed from 3.57 pounds to 3.46 pounds. The 13.3" widescreen 2560x1600 (227 ppi) display is unchanged while some external ports and Wi-Fi capabilities have been improved. The Late 2013 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 model the Late 2013 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 13" Late 2013 model MacBook Pro with Retina Display laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina Late 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display Late 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display Late 2013 earned a 1 out of 10 in iFixit's repairability assessment. Watch the Teardown Review for more:
