MacBook Left Clutch Hinge
  • MacBook Left Clutch Hinge
US$ 14,99
US$ 14,99
Productdetails
Beschrijving
Beschrijving
Looking for a Clutch replacement?
Then this is the part you need! Located on left side when facing screen.
Compatibiliteit
Compatibiliteit
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Specificaties
Specificaties
Part #:
922-7402
Compatibiliteit
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
dropped computer and sheared the hinge rod on the the left hinge clutch assembly
Mijn oplossing
99% successful. unfortunately, i did not understand how the inverter plugs was meant to come off the main board and ended up breaking the pins off of the main board, so now the computer is toast. oh well. it ALMOST wo . . .
Gebruikersavatar
Mijn probleem
I had a student complain about the screen coming off...
Mijn oplossing
It was simple and easy with the right parts and tools
Mijn advies
Don't forget to put the screws back in exactly where you got them from...
Gebruikersavatar
Mijn probleem
My Macbook fell off the couch and broke the left hinge. This made the screen unable to hold itself up.
Mijn oplossing
Thanks to iFixit's guides, I had no problem repairing it.
Mijn advies
Take your time, and have somewhere to put the screws for each step... there are tons of screws.
Gebruikersavatar
Mijn probleem
Due to mishandling, the Macbook had a broken left hinge and the Inverter cable had been pulled out of it's plug at the motherboard end. It was a write off until I saw your website. Identified the correct Inverter cable and ordered the bits.
Mijn oplossing
The machine came apart and I replaced the hinge and cable, c . . .
Gebruikersavatar
Mijn probleem
My kid dropped his MacBook and broke the hinge. Apple said fixing the hinge was a major repair. He lived with it for a while but when the HD also died I decided to try to fix it myself.
Mijn oplossing
Went fine. Fixing the hinge really was a big, time consuming job since it required disassembly of the display. But . . .
Gebruikersavatar
Mijn probleem
I broke the left hinge when I dropped my mac. The Apple store quoted me $800 to fix it. What's the point? I was ready to buy a new Mac for that price. I think that is what Mac was hoping for. I did it myself for $100.
Mijn oplossing
Directions said difficult. I have never taken apart a computer apart but I finished . . .
Geef meer weer
