Repareer je spullen
Recht op reparatie
Winkel
MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
  • MacBook Core Duo/Santa Rosa/Penryn LCD Mounts
US$ 7,99
US$ 7,99
Productdetails
Beschrijving
Beschrijving
LCD hanging on by a thread?
Lock it down with some LCD mounts! Includes LCD mounts and airport antenna cables.
This part works with model A1181 MacBooks with 2 antenna connectors. If your MacBook has 3 antenna connectors you need the Core 2 Duo hinge mounts.
Compatibiliteit
Compatibiliteit
  • 1.83 or 2 GHz Core Duo MacBooks
  • 2.0 (Santa Rosa) or 2.2 GHz Core 2 Duo MacBooks
  • 2.1 or 2.4 GHz Core 2 Duo MacBooks
  • 2.0 GHz (Early 2009) Core 2 Duo MacBooks
  • 2.13 GHz (Mid 2009) Core 2 Duo MacBooks
Compatibiliteit
MacBook Core 2 Duo
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
WIFI antenna wire was broken where it passes through the hinge of the display.
Mijn oplossing
The online guide was helpful - take the time to go slow and follow each step.
Mijn advies
Set aside enough time to do the repair right - keep track of where the screws from each step go so you don't get them mixed up later.
Gebruikersavatar
Mijn probleem
My airport would only work if the computer did not move after startup. If moved the airport would turn off and could not be turned back on without restarting. After researching the problem I deduced that it was probable that the antenna wires had been pinched/worn from the screen opening and closing . . .
