Repareer je spullen
Recht op reparatie
Winkel
MacBook (Core Duo/Core 2 Duo) Inverter Cable
  • MacBook (Core Duo/Core 2 Duo) Inverter Cable
US$ 19,99
US$ 19,99
Productdetails
Beschrijving
Beschrijving
Having an issue with your MacBook's backlight?
Replacing this part may solve the problem! Connects the logic board to the display inverter.
Before ordering a new inverter cable, be sure you are buying one with the correct connector for your machine. The Santa Rosa/Penryn inverter cable has a much slimmer three-wall connector on the side that connects to the logic board.
Compatibiliteit
Compatibiliteit
  • 1.83 or 2 GHz Core Duo MacBooks
  • 1.83, 2, or 2.16 GHz Core 2 Duo MacBooks (excluding Santa Rosa/Penryn)
Specificaties
Specificaties
Part #:
922-7612
Compatibiliteit
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2139) 2.16 GHz
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
Display went dark. Diagnosed problem to a display backlight inverter or data cable.
Mijn oplossing
Ifixit help guides allowed me to try an initial repair by switching parts from another MacBook that had died years ago. That operation was not successful, but based on my comfort with Ifixit's help guides, and the r . . .
Gebruikersavatar
Mijn probleem
Screen would light up momentarily at startup and then backlight would go out
Mijn oplossing
Took a shortcut and just removed the monitor bezel , three screws, and the plastic cover over the inverter. Replaced the inverter, refitted the cable and closed it back up. Took less than 10 minutes.
Mijn advies
No need to take the who . . .
Gebruikersavatar
Mijn probleem
The backlight would flicker when the display was moved up and down. Eventually, it became harder and harder to get it to stay on.
Mijn oplossing
Followed the directions going both ways and the laptop worked great when finished. It is very easy to chip the edges of the screen bezel and the keyboard frame when popp . . .
Gebruikersavatar
Mijn probleem
The backlight of my MacBook (1.1) was flickering. It was very annoying, so I looked up, what could cause the problem. I found out, that it has to be the inverter or it's cable. I bought both to be on the save side.
Mijn oplossing
The repair was a lot of fun and pretty easy too. The guides helped me a lot and my Mac . . .
Gebruikersavatar
Mijn probleem
My backlight was flashing as I opened/closed the screen of my MB Core 2 Duo (not Santa Rosa). In the most critical times I had to spend minutes finding the perfect angle of screen opening to have a constant backlight.
Mijn oplossing
I took it with patience, and had to completely open my MB four or five times in the . . .
Gebruikersavatar
Mijn probleem
When waking from sleep. backlight is intermittent as display is raised. Examination shows that the image is always there, but the lighting is dependent on display/top cover position. But, the inverter cable may not be the problem. Could be loose/dirty plug, etc.
Mijn oplossing
Haven't replaced cable yet, as the co . . .
Gebruikersavatar
Mijn probleem
The screen kept going black, would only work when tilted, and in certain angles.
Mijn oplossing
The screen is working perfectly now. It did take me a whole day, and included a lot of swearing but considering I have never fixed or tinkered with any electronics before it went remarkably well. I had a bit of a scary m . . .
Gebruikersavatar
Mijn probleem
My screen wouldn't come on when I opened my MacBook.
Mijn oplossing
It was a long process and we found that we had ordered the wrong inverter cable the first time. Without being able to see my screen, I ordered the Core Due/Core 2 Duo Inverter Cable and I actually needed the Santa Rosa. We ordered the part and ins . . .
Gebruikersavatar
Mijn probleem
I have had my MacBook for more than 6 years now. It still runs great. I have replaced a hard drive, before it started failing, have re-installed the OS, upgraded RAM, had to get a new mag safe power adapter, replaced the screen due to dropping it (another great ifixit repair guide I followed), and h . . .
Gebruikersavatar
Mijn probleem
The display on my trusty 2007 Macbook started to flicker in a way that was very sensitive to the position of the screen, and could be improved by lightly squeezing the surround at the bottom left of the display. Apparently a bad connection.
Mijn oplossing
First I used the ifixit guide to disembowel the MacBook, hop . . .
Geef meer weer
