Repareer je spullen
Recht op reparatie
Winkel
MacBook Air 13" (Mid 2011) Trackpad
  • MacBook Air 13" (Mid 2011) Trackpad / With Bracket
  • MacBook Air 13" (Mid 2011) Trackpad / Without Bracket
US$ 89,99
US$ 89,99
Productdetails
Beschrijving
Beschrijving
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Air 13" (Mid 2011).
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
Compatibiliteit
Compatibiliteit
  • MacBook Air 13" A1369 Mid 2011
Specificaties
Specificaties
Part #:
922-9962
Compatibiliteit
MacBook Air 13" Mid 2011
A1369 (EMC 2469) 1.7 GHz
A1369 (EMC 2469) 1.8 GHz
Reparatieverhalen
Gebruikersavatar
Mijn probleem
The trackpad was randomly clicking when moving the mouse. I replaced the trackpad which solved the problem.
Mijn oplossing
Opening the mac was not too difficult. However, unplugging the connector was tricky.
Mijn advies
Gebruikersavatar
Mijn probleem
Trackpad stopped clicking got spongy when pushing down unlike before. Started to get stuck when dragging things.
Mijn oplossing
Man, those are some tiny screws, glad I don't have Andre the Giant hands. Took me a few tries to get the positioning of the set screw just right but no problems, no extra parts/screws, and . . .
Gebruikersavatar
Mijn probleem
My trackpad started randomly clicking, selecting everything, moving things around... very bad for a developer!
Mijn oplossing
It was a cinch. 20 minutes tops.
Mijn advies
Spend a little time with that last adjustment screw before putting everything back together so you don't have to open it all again.
Gebruikersavatar
Mijn probleem
Common problem with this generation of Macs: the trackad sometimes "clicks by itself"
Mijn oplossing
The repair was super-simple but the excellent guide was still nice to have for safety.
Mijn advies
By using the guides anyone can repair almost anything! However, you should read all text carefully!
Gebruikersavatar
Mijn probleem
Basically the trackpad that I had was registering click events when I wasn't clicking (yes, I had, and always have had, tap to click disabled). So as you can imagine, trying to open new tabs? #nope, trying to move a window? #hahanope
Mijn oplossing
Check out the writeup on my blog!!
http://andrew.sc/
Mijn advies
PLEASE PLEAS . . .
Geef meer weer
