Mijn probleem
My trackpad was cracked and couldn't click
Mijn oplossing
It went well.
Mijn advies
I suggest using a desk lamp, bright flashlight, or any bright light. I also recommend using a small magnifying glass.
Dit product is niet beschikbaar in jouw land.
Artikelcode: IF108-054-3
US$ 109,99
In de aanbieding
A-voorraad gebruikte onderdelen zijn in uitstekende staat
B-voorraadonderdelen hebben kleine cosmetische slijtage
C-voorraadonderdelen hebben grote cosmetische slijtage, maar zijn volledig functioneel
US$ 109,99
In de aanbieding
Niet op voorraad
We hebben niet zo veel voorraad beschikbaar
Productdetails
Beschrijving
Beschrijving
Replace a damaged trackpad and restore the touch sensitivity of your Mid 2013 to Early 2015 model 11" MacBook Air laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control. Fix these issues with this replacement part.
Compatibiliteit
Compatibiliteit
Specificaties
Specificaties
Compatibiliteit
Reparatieverhalen
It went well.
When attempting to clean and adjustment the trackpad I ended up breaking the keyboard ribbon cable zif connector - So I ended up having to purchase a new trackpad.
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyboard ribbon. My laptop now works great - so I'm happy.
Be really careful when lifting the zif connectors to remove and insert the ribbons. It's very thin plastic and if it breaks you have to replace the entire trackpad. I used the All-new Pro Tech Toolkit, which is awesome. Great tools, great case. Highly recommend this kit - I
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyb . . .
Wordt vaak samen gekocht
Aanbevolen producten
