Repareer je spullen
Recht op reparatie
Winkel
MacBook Air 11" (Late 2010-Early 2015) Right Speaker
  • MacBook Air 11" (Late 2010-Early 2015) Right Speaker
  • 360°
360
US$ 9,99
US$ 9,99
Productdetails
Beschrijving
Beschrijving
Replace a right speaker in your Late 2010 to Early 2015 MacBook Air 11" laptop and fix issues with sound output.
An aging or malfunctioning speaker may have buzzing noises or cut out unexpectedly. Restore your laptop's sound quality with this replacement part.
Compatibiliteit
Compatibiliteit
  • MacBook Air 11" A1370 Late 2010 to Mid 2011
  • MacBook Air 11" A1465 Mid 2012 to Early 2015
Specificaties
Specificaties
Part #:
922-9672, 923-0435, 923-00498
Compatibiliteit
MacBook Air 11" Early 2014
A1465 (EMC 2631) 1.4 GHz
A1465 (EMC 2631) 1.7 GHz
MacBook Air 11" Early 2015
A1465 (EMC 2924) 1.6 GHz
A1465 (EMC 2924) 2.2 GHz
MacBook Air 11" Late 2010
A1370 (EMC 2393) 1.4 GHz
A1370 (EMC 2393) 1.6 GHz
MacBook Air 11" Mid 2011
A1370 (EMC 2471) 1.6 GHz
A1370 (EMC 2471) 1.8 GHz
MacBook Air 11" Mid 2012
A1465 (EMC 2558) 1.7 GHz
A1465 (EMC 2558) 2.0 GHz
MacBook Air 11" Mid 2013
A1465 (EMC 2631) 1.3 GHz
Toon 3 meer apparaten
Reparatieverhalen
Gebruikersavatar
Mijn probleem
I enjoy hearing my music loud. My MacBook Air not so much - i blew one of the speakers
Mijn oplossing
Repairing was a piece of cake, the guide was perfectly clear I din't have any problems with it.
Mijn advies
nope
Gebruikersavatar
Mijn probleem
the sound coming out of my mba was terrible. it was broken and i was using external speakers.
Mijn oplossing
Finding the right part from ifixit was great and with the clear how-to instructions it was a cinch. thanks and kudos to you!
Mijn advies
May i suggest, that you identify the orientation when you say the "right speaker".
Gebruikersavatar
Mijn probleem
My right speaker was distorting very badly.
Mijn oplossing
Fantastic. Couldn't have been easier. The tools and guide are fantastic. Replacing the speakers is a pretty simple task when you have the correct tools.
Mijn advies
Be very careful when tightening the screws. They are small and somewhat soft and you can strip the heads . . .
Gebruikersavatar
Mijn probleem
Right speaker on my MacBook Air blew out when I was using an app to play audio louder than the OS limits... oops.
Mijn oplossing
Super easy. Took all of 10 minutes, maybe? Normally I would have had to do the whole Apple Store repair process; this was so much better, and fun.
Mijn advies
Follow the guide that's here well, and yo . . .
Gebruikersavatar
Mijn probleem
I destroyed my Macbook Air Speakers using a little peace of software called BOOM.
Mijn oplossing
I just followed the replacement guide on ifixit and it was super easy.
Mijn advies
Nothing to add here
Gebruikersavatar
Mijn probleem
Installed a third party volume boosting app from the App Store on my Macbook Air. Shortly after the right speaker started crackling!
Mijn oplossing
Easy. Followed the instruction guide step by step. You may think you do not need to buy the spudger; don't be fooled. It's an essential tool.
Mijn advies
Get the spudger. Make sur . . .
Gebruikersavatar
Mijn probleem
A strange cracking sound started when I watched a movie and after some tests, I've discovered the need of the speaker to be changed.
Mijn oplossing
The repair was fine, I'm happy with the results. The speaker have some kind of glue or tape to help the speaker to be fixed. To remove it need some effort but nothing d . . .
Gebruikersavatar
Mijn probleem
The right speaker sounded awful
Mijn oplossing
This is very easy and takes only 15 minutes
Mijn advies
Nothing
Geef meer weer
