9.5 mm PATA Optical Bay SATA Hard Drive Enclosure
  • 9.5 mm PATA Optical Bay SATA Hard Drive Enclosure
US$ 39,99
US$ 39,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
Increase the storage space in your laptop by replacing the optical drive with a second SATA hard drive or SSD.
Notitie
This enclosure does not work with ATA drives or hard drives thicker than 9.5 mm.
By replacing your optical drive, you can install up to a 1 TB hard drive in this enclosure to increase your available storage space. This drive also is available via Target Disk Mode when connected to another Mac using Firewire.
Notitie
Compatible with all MacBooks (excluding Early or Mid 2009 MacBooks, MacBook Unibody and MacBook Air) and all 15" MacBook Pros (excluding Unibody).
Installatievideo
Compatibiliteit
MacBook Core 2 Duo
1.83 GHz
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
MacBook Pro 15" Core 2 Duo Model A1211
2.16 GHz
2.33 GHz
MacBook Pro 15" Core 2 Duo Models A1226 and A1260
2.4 GHz (Penryn)
2.4 GHz (Santa Rosa)
2.5 GHz (Penryn)
2.6 GHz (Penryn)
2.6 GHz (Santa Rosa)
MacBook Pro 15" Core Duo Model A1150
1.83 GHz
2 GHz
2.16 GHz
Toon 2 meer apparaten
Reparatieverhalen
Avatar
Archelon's Story Photo #365581
Archelon's Story Photo #365583
Archelon's Story Photo #365584
Mijn probleem
The original 200 Gb hard drive was no longer sufficient for my storage needs, so it was time to upgrade it to a 1 Tb (hybrid) drive. The DVD drive was swapped out with the 200 Gb drive to have Windows 8.1 as the dual boot option.
I have an older set of tools that generally work very well when deal . . .
Avatar
lsdejones's Story Photo #444342
lsdejones's Story Photo #444343
Mijn probleem
Never used the optical drive on my old Macbook so I figured I would replace it with a HDD. Heard about doing this online so I thought I would give it a shot. Having an extra 2.5 inch HDD lying around was also good motivation.
Mijn oplossing
Good and bad. I did not realize there were so many screws in a Macbook. Sa . . .
Avatar
Nathan Denkin's Story Photo #874514
Mijn probleem
My son gave me a MacBook Pro 3,1 that he said had become unusable. I replaced the HDD with a 480 GB SSD and upgraded the RAM from 2GB to 6GB. The optical drive was not working and I wanted to replace it with a HDD. Problem: the optical drive used a PATA connection and large PATA drives are essen . . .
Avatar
Zachary Wheeling's Story Photo #750163
Mijn probleem
MacBook Core 2 Duo 2.16 Ghz 4GB RAM 240GB Intel SSD 160GB Apple HDD..... Screen Bezel clips were broken and wanted to change color from black to white. Also wanted a dual hard drive as I had recently purchased an SSD to speed up my MacBook C2D and wanted to run three Mac OS's as well as a copy of . . .
Avatar
Mijn probleem
Wanted to make an older black Macbook in to a travel Photobackup unit
Mijn oplossing
Preety smoothly one or two issues figuring out what screws went where but was preety much install and go
Mijn advies
Take your time and dont rush and pay attention
Avatar
Mijn probleem
Just wanted more storage capacity.
Mijn oplossing
It was smooth! iFixit has awesome instructions! Highly recommend any fix! YOU CAN DO IT!
Mijn advies
YOU CAN DO IT!!!
Avatar
Mijn probleem
I got a used 2007 Macbook Core 2 Duo a couple years ago. When I got it the SuperDrive wasn't reading discs, so one of the first things I did was replace it. However, as that era of SuperDrives were notoriously faulty, my new SuperDrive also failed, so bad that I had to pry a DVD out of it with twe . . .
Avatar
Mijn probleem
I have other more powerful desktops in the house and office but for some reason I continue to want to use my MacBook Pro it is my workhorse. Well, my work horse has been acting a little like an old mare for the past year, so I decided to upgrade the RAM an solve other problems. Adding more hard dri . . .
Avatar
Mijn probleem
I never use my DVD drive anymore and when I travel I still prefer to take my MacBook Pro with me vs my windows laptop. So I wanted to boost the performance on this little guy.
Mijn oplossing
The repair guide went smoothly. Because I was replacing the optical drive with an ssd I was focused on making it a fusion . . .
Avatar
Mijn probleem
Wanted a faster Macbook. Added SSD as main drive and used previous drive in adapter for second drive in place of the DVD.
Mijn oplossing
15 minute installation. No issues whatsoever.
Mijn advies
Take it easy, follow the instructions.
Geef meer weer
