12.7 mm SATA Optical Bay SATA Hard Drive Enclosure
  • 12.7 mm SATA Optical Bay SATA Hard Drive Enclosure
US$ 19,99
US$ 19,99
We zullen een bericht sturen als het product weer op voorraad is.
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Productdetails
Beschrijving
Beschrijving
Increase the storage space in your computer by replacing the optical drive with a second SATA hard drive or SSD.
Notitie
This enclosure does not work with ATA drives or drives taller than 12.5mm. By replacing your optical drive, you can install up to a 1 TB hard drive in this enclosure to increase your available storage space. This drive also is available via Target Disk Mode when connected to another Mac using Firewire.
Notitie
Compatible with all Model A1283 Mac minis Mid 2010 Model A1347 Mac minis iMac Intel 20"" EMC 2266 iMac Intel 24"" EMC 2267 iMac Intel 21.5"" EMC 2308 and 2389 iMac Intel 27"" EMC 2309 and 2374.
Installatievideo
Compatibiliteit
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
EMC 2308 3.06 GHz
EMC 2308 3.33 GHz
iMac Intel 21.5" EMC 2389
EMC 2389 3.06 GHz
EMC 2389 3.2 GHz
EMC 2389 3.6 GHz
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 and 2374
2.66 GHz (Late 2009)
2.8 GHz (Late 2009)
3.06 GHz (Late 2009)
3.33 GHz (Late 2009)
Mac Mini Mid 2010
2.4 GHz (Core 2 Duo, Mid 2010)
2.66 GHz (Core 2 Duo, Mid 2010)
Mac Mini Model A1283
2 GHz (Core 2 Duo)
2.26 GHz
2.53 GHz
2.66 GHz
Toon 4 meer apparaten
Reparatieverhalen
Avatar
Kevin Shank's Story Photo #950368
Kevin Shank's Story Photo #950365
Kevin Shank's Story Photo #950367
Mijn probleem
Wanted to replace my Superdrive in 2010 Mac mini that had been disabled way back when I first upgraded to Snow Leopard. Parts arrived very quickly. Instructions were simple. Added a Samsung 500gb SSD. Good to go.
Mijn oplossing
Had to troubleshoot after the first go around. Computer became extremely hot! I realized . . .
Avatar
Mijn probleem
Defective optical drive and need for a life extension of my Mac
Mijn oplossing
No problem at all!
Mijn advies
Does not boost overall performance of the Mac itself but might give me an other year or two joy with my Mac for a minimum of $.
Avatar
Mijn probleem
I'm a full-time computer repair specialist who does side work for friends. Sometimes, those friends are customers whose computers we can't fix (because we don't carry the parts) or aren't allowed to fix (because it's too complicated of a repair). This was one of those times. The iMac wouldn't boot a . . .
Avatar
Mijn probleem
The iMac was a mid-2010 i5 3.0GHz, not too shabby but was getting a bit long in the tooth for opening up Adobe programs and took forever when switching logged in users.
Mijn oplossing
This was the second iMac I've done this on now, and the swap was simple and easy. I would say the 12.7mm SATA Optical Bay does not . . .
Avatar
Mijn probleem
The optical drive did not work so I installed dual Hard Drive instead.
And I want to upgrade to El Kapitan and install some more ROM.
Mijn oplossing
I followed the guide from IFIXIT for how to Install Mac Mini Mid 2010 Dual Hard Drive. Very good instruction even for a Norwegian amateur.
I first Cloned the old har . . .
Avatar
Mijn probleem
Slow IMAC needed some action!
Replaceing the optical drive with an 250GB SSD (from Crucial) was a natural choice!
Using the new SSD as startup disk.
Mijn oplossing
Beeing very carefull and spending a litle extra time on the echange process - Succsess!
OSX and applications now run on the SSD. User on the old h.dis . . .
Avatar
Mijn probleem
Las computadoras de disco mecánico ya tardaban mucho en encender y a cada rato salía la pelota playera dando vueltas, signo de que el sistema está pensando o atorado.
Mijn oplossing
La reparación fue sencillísima, las cosas que compré en iFixit me llegaron rapidísimo! Y las guías me sirvieron perfectamente. . . .
Avatar
Mijn probleem
My wife and I, being on a limited budget, needed new iMacs. Not being able to afford one for each of us, we decided to take a gamble on trying to upgrade the ones we already had. They are both mid 2010 21.5" iMacs. Both had become slow as Christmas. I had read about this website and did my home . . .
Avatar
Mijn probleem
Wanted to speed up my iMac performance. The RAM was already maxed, so the only thing left to do was upgrade the what's drive to an SSD.
Mijn oplossing
It was pretty smooth. Much easier than I thought it would be.
Mijn advies
I think it's worthwhile to upgrade the ram & SSD on your older Mac before going out and buying a new one . . .
Avatar
Mijn probleem
Upgrade mid 2010 iMac 21.5 to SSD
Mijn oplossing
I have successfully upgraded my iMac mid 2010 21.5 inch to Samsung Pro 256G SSD using the SATA optical bay hard drive enclosure. Initially, I ordered the wrong part and iFixit switched it for me prior to shipping. Second, the product arrived couple days late (most . . .
Geef meer weer
