Wat je nodig hebt
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Locate the screw that secures the CD / DVD drive. With the Philips screwdriver unscrew this one.
Finally remove the CD / DVD drive from its location.
TO REASSEMBLE YOUR DEVICE FOLLOW THESE INSTRUCTION IN REVERSE ORDER.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
irlanda helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
