Wat je nodig hebt
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Once the bottom cover is removed you can start disassembling the keyboard.
Start by turning the computer over and then unscrew the screw shown in image 2 of this step.
Then using the screwdriver unscrew the bar that hides the screws fixing the keyboard.
To reassemble your device, Follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
100%
irlanda helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
