Inleiding
Intel Core i5 4200M Haswell Processor (CPU) Replacement
Wat je nodig hebt
Slide the latch on the right to the unlocked position.
Slide the latch on the left to the unlocked position.
Remove the battery pack from the slot.
With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
Now you can remove the bottom cover.
Using a Phillips screwdriver, unscrew the four captive screws securing the heatsink to the motherboard.
Remove the heatsink.
The processor and its retention mechanism is now visible.
Met dank aan deze vertalers:
100%
Jerry Wheeler helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
