Ga door naar hoofdinhoud
why! N240BU Replacing the LCD screen
Wat je nodig hebt
  1. why! N240BU Replacing the LCD screen, Battery: stap 1, afbeelding 1 van 2 why! N240BU Replacing the LCD screen, Battery: stap 1, afbeelding 2 van 2
    • Start by unlocking the right locking latch.
    • Then, by simultaneously unlocking the left latch, lift the battery out of its socket.
  2. why! N240BU Replacing the LCD screen, Access to main components: stap 2, afbeelding 1 van 2 why! N240BU Replacing the LCD screen, Access to main components: stap 2, afbeelding 2 van 2
    • Begin by spotting the dummy memory card.
    • Then, remove it and put it on your workplan.
  3. why! N240BU Replacing the LCD screen: stap 3, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 3, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 3, afbeelding 3 van 3
    • Locate the 15 screws that hold the bottom cover of the device in place.
    • Unscrew them and place them on your work surface.
    • Then, un-clip the bottom cover, starting with the side shown in the third picture.
  4. why! N240BU Replacing the LCD screen, LCD screen: stap 4, afbeelding 1 van 3 why! N240BU Replacing the LCD screen, LCD screen: stap 4, afbeelding 2 van 3 why! N240BU Replacing the LCD screen, LCD screen: stap 4, afbeelding 3 van 3
    • In order to remove the LCD screen, you must remove the connection cables from the Wi-Fi chipset.
    • Then locate the two connectors on the LCD screen.
    • Disconnect the first connector.
  5. why! N240BU Replacing the LCD screen: stap 5, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 5, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 5, afbeelding 3 van 3
    • Peel off the tape from the second connector.
    • Then disconnect the second connector.
    • Locate the SSD M.2 drive.
  6. why! N240BU Replacing the LCD screen: stap 6, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 6, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 6, afbeelding 3 van 3
    • Then dismount this disk because it must release the connection cables of the Wi-Fi chipset.
    • Free Wi-Fi connection cables now
    • Now locate the two screws that secure the screen to the rest of the Laptop (fan side)
  7. why! N240BU Replacing the LCD screen: stap 7, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 7, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 7, afbeelding 3 van 3
    • Now locate the two screws that secure the screen to the rest of the Laptop (the other side).
    • Then lift the Laptop as shown in the second image of this step.
    • Unscrew the first screw.
  8. why! N240BU Replacing the LCD screen: stap 8, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 8, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 8, afbeelding 3 van 3
    • Then unscrew the second screw.
    • Rest the Laptop as shown in the second image of this step and unscrew the third screw.
    • Then the fourth screw.
  9. why! N240BU Replacing the LCD screen: stap 9, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 9, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 9, afbeelding 3 van 3
    • With the four screws unscrewed, separate the screen from the rest of the Laptop. Note that the hinge remains attached to the screen.
    • On the screen near the hinge now locate the two caches screws on the left.
    • Then look for those on the right.
  10. why! N240BU Replacing the LCD screen: stap 10, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 10, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 10, afbeelding 3 van 3
    • Now remove the screw covers near the left hinge.
    • first on the right side of the hinge.
    • then on the left side.
  11. why! N240BU Replacing the LCD screen: stap 11, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 11, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 11, afbeelding 3 van 3
    • Repeat near the right hinge
    • .Now return to the hinge on the left side and unscrew the outer screw.
  12. why! N240BU Replacing the LCD screen: stap 12, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 12, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 12, afbeelding 3 van 3
    • Then unscrew the inner screw.
    • Repeat on the side of the right hinge.
  13. why! N240BU Replacing the LCD screen: stap 13, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 13, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 13, afbeelding 3 van 3
    • You can now gently unclip the screen cover.
    • Locate the left hinge screw cover.
    • Locate the right hinge screw cover.
  14. why! N240BU Replacing the LCD screen: stap 14, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 14, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 14, afbeelding 3 van 3
    • Gently remove the screw cover on the left hinge.
    • Also remove the screw cover on the right hinge.
    • Once the screw caps are removed you will see the fixing screws.
  15. why! N240BU Replacing the LCD screen: stap 15, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 15, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 15, afbeelding 3 van 3
    • Now unscrew the screw on the left hinge.
    • Then unscrew the screw on the right hinge.
    • Once this is done you can now remove the hinge cover (left).
  16. why! N240BU Replacing the LCD screen: stap 16, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 16, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 16, afbeelding 3 van 3
    • Left hinged cover removed.
    • Then remove the cover from the right hinge.
    • Right hinge cover removed.
  17. why! N240BU Replacing the LCD screen: stap 17, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 17, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 17, afbeelding 3 van 3
    • once these operations are done you see the LCD screen ready to be dismounted.
    • Now locate the screws that secure the LCD screen to the bracket and unscrew them. Two on the left.
    • Two on the right.
  18. why! N240BU Replacing the LCD screen: stap 18, afbeelding 1 van 3 why! N240BU Replacing the LCD screen: stap 18, afbeelding 2 van 3 why! N240BU Replacing the LCD screen: stap 18, afbeelding 3 van 3
    • Once the screws are unscrewed, lift the LCD screen gently and flip it over.
    • You will then see the connection cable of the screen.
    • Locate its connector.
  19. why! N240BU Replacing the LCD screen: stap 19, afbeelding 1 van 2 why! N240BU Replacing the LCD screen: stap 19, afbeelding 2 van 2
    • Disconnect the cable.
    • And here you can now put it on your work plan.
Conclusie
To reassemble your device, Follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
irlanda helpt ons de wereld te repareren! Doe je mee?
Begin met vertalen ›
Felice Suglia
33.538 Reputatie
283 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 494
